- Joined
- Dec 27, 2025
- Messages
- 3
Hiya gents,
I have a 2012 Mustang with the 3.7L that is specced for using 5w20 with Ford WSS-M2C945-A.
I live in Canada and its getting quite cold here. I know that the 5w20 is certified for down to -30C/-22F, but already at -20C/-4F I am seeing much more laboured cranking and even brief oil pressure switch going off for half a second for the oil is pumped through.
I was thinking of switching to 0w20 to slightly alleviate this. I run with Pennzoil Ultra Platinum and my new 0w20 bottle is specced WSS‑M2C972‑A1, which appears to be a pretty recent spec (2025) in addition to API/ILSAC that are also pretty new.
On Ford's "servicecontent" online manuals for more recent Lincolns with the same 3.7L motor, they advise using 0w20 in "severe cold conditions" with a spec that seems to predate or is a previous version of the 972-A1 mentioned.
The question is will this be suitable for the car? Pennzoil's data sheet also says that the 0w20 products will work in 5w20 applications (see attached image).
