Took me many years to learn this- and I still backslide- listen or fix
GON
$150 Site Donor 2025
White Sands, NM
The situation in this video is the hardest challenge in my marriage. Listening to my wife. My wife wants to explain in detail a situation/problem/etc. I stop listening and want to immediately go into fix mode. My wife simply wants me to listen. My wife gets frustrated that I want to fix over listening.
I do better with shorter chunks of information. When she (or anyone) goes on and on in exhaustive detail, it is so hard to stay focused. It's definitely a two-way street. She is learning to give shorter, more meaningful chunks of info while I am learning to listen and not go into fix mode. I have a similar issue at work: certain people can't answer a yes no question with a yes or no. They have to provide several minutes of background info that is usually inconsequential. I need a quick answer so I can move forward and fix. That behavior tends to come home and contributes to the fix mode that husbands typically drop back to. Marriage (and communication in general) are tough things when dealing with vastly different personalities.
Arguing with a woman is often like fighting the wind-you have to let it stop blowing on it's own! Then reason with it. Once she has gotten over what was bothering her, then move onward. I learned this from my aunt, my Mom's sister, and observing her fights with my Grandma, her mom. They would go back & forth, practically raging at each other, over nothing. I would just let them go off until they got tired...
I’m sorry, what?
  • Haha
Reactions: GON
It took me years to accept that you must turn off a thermostat because setting the temp either so hi or so low that the system would not turn on is not acceptable.
Oh and same for pushing in the button on the clothes washer because it really turns off the machine.
In my lifetime I have found that the majority of men when asked a question will give a direct answer. Ask any woman the same question and she will circle the wagon many, many times before you get an answer to the same question. And I have learned that her answer is always correct. I mean, what was I thinking.
I’m guilty of this a whole, whole lot….
I think of an answer or better way to think of things or better way to handle things.
And I am guilty of assessing blame on etc etc etc…
I am like.. stop complaining… and do SOMETHING about your problem…
Every now and then I do actually listen to her. And not try to give her an answer or try to give her a way to handle a circumstance.
  • Like
Reactions: GON
