thin perhaps not as good as i thought
Quote:
link for STI bits that can be ordered for the current BRZ, they show Motul 5W-40 and 15W-50.
Well now you really went and upset the fan club.
Originally Posted By: Trav
Quote:
Question: why does it matter if you don't own one of their turbo charged engines?
Simple i will probably end up working on these at some point.
Using that argument then why are we here on BITOG anyway if only the oil for use in what we own is important.
Quote:
Ford shifted to turbochargers, which tend to run heat the oil more--so they changed their lubrication strategy
Just a minute Ford also said..
Quote:
Q. Engine oil is a carrier for heat with the higher rpm's on some of the smaller engines can we expect shorter engine life?
A: No. The oil is specifically designed to withstand engine heat.
So it cant take the heat in a turbo engine?
By Fords own actions not words they have backtracked on a lot of their talking points since that article thats all i'm saying.
The Ford Ecoboost turbos have water cooled bearing jackets. See third paragraph from the bottom.
http://media.ford.com/article_display.cfm?article_id=29946
Originally Posted By: Volvohead
Originally Posted By: JOD
But there is a mountain of evidence out there to support the use of thinner oils in most applications,
And therein lays the crux of this silly little battle between you (and a couple of others) on one side, and people like Trav who see inside many engines in the field on the other.
Well, Trav, I guess I'll ignore my private advice to you just this once.
Rather than simply make generalized backhanded insults of people like Trav ("this is what they do in Europe" is frankly condescending), why don't you lay out specifically, with actual field and engineering data, studies and evidence, your "mountain of evidence" supporting the use of thinner oils in most applications -- including where engine manufacturers have in fact specified a heavier oil.
Citing the statements of a manufacturer specifying a 20 wt oil in an engine is not evidence supporting the use of thinner oils in most applications. It's evidence supporting its use in THAT application and engine.
Presenting the UOA of a 20wt oil in an engine where the manufacturer recommends that weight is not evidence supporting the use of thinner oils in most applications. It's evidence supporting the manufacturer's recommendation for THAT application and engine.
These are your contentions. They run directly counter to the manufacturer's express recommendations in some instances, particularly for European engines. I don't fault people like Trav for their strong response, when the field and manufacturer recommendations are contradicting YOU.
Trav is right to ask for credentials. You and several others are speaking as experts might, and present opinions contrary to the engine manufacturers themselves in some instances. In my line of work, it's what we call an adverse expert.
So the evidentiary burden is on you and your fellow advocates.
Thus far, other than parroting a simplistic, mono-dimensional formula on "operational viscosities" using a Widman calculator that ignores the mechanical and other engineering parameters involved in effective lubrication of a modern IC engine's cylinder and bearing systems, nothing meaningful or technically specific has been presented to support the rogue thesis that thinner oils are supported in most applications.
Oil temperature and pressure and mere operational viscosity is not evidence that thinner oils are supported in most applications.
Contending that current synthetic 20wt oils are "better" than earlier generation or conventional 30wt oils is not evidence that thinner oils are supported in most applications.
And insulting and belittling detractors for "not understanding" self-conclusory declarations is not an argument, nor does it improve your intellectual cadence.
Where's the actual evidence of which you speak, advocate?
Were this a court case, you would not survive a motion for summary judgment. I'm not sure you and your colleagues would even survive a Daubert motion.
Saying there's evidence is not the same as presenting it.
Roll out your actual evidence. Take us to the mountain.
Let's see the actual field and lab studies and data supporting the use of thinner oils in most applications -- even where the manufacturer recommends differently.
Maybe then Trav and some others here might be better convinced.
Sorry, but you're dead wrong. "what they do in Europe" isn't an insult, it's continually given as a rationalization as to why recommendations in the US are sub-optimal. If you feel that's insulting, then I'm not really sure what to say.
As far as the evidence, what exactly do you want? I've already provided links in this thread that deal with hths and engine wear. You could start here:
“Effects of Valve Train Design Evolution on Motor Oil Anti-Wear Requirements”, J.C Bell, paper CEC97-EL02, 5th CEC International Symposium on the Performance
Evaluation of Automotive Fuels and Lubricants, 1997
Engine Friction and Bearing Wear. III. The Role of Elasticity in Bearing Performance”,E.H. Okrent, ASLE Transactions, 7, 1964
“The Viscoelastic Properties of Multigrade Oils and Their Effect on Journal-Bearing Characteristics”, B.P. Williamson, K. Walters, T.W. Bates, R.C. Coy & A.L. Milton, J.
Non-Newtonian Fluid Mech., 73, 1997
"Piston Ring Oil Film Thickness - The Effect of Viscosity”, S.L. Moore, SAE 850439
“Influence of Piston Ring Gaps on Lubricating Oil Flow into the Combustion Chamber”,K. Nakashima, S. Ishihara & K. Urano, SAE 952546
These are all published scientific papers which deal with various facets of how viscosity relates to engine wear. The source document is here , and there are some citations from those texts, which accompanying charts, which detail the relationship between wear and viscosity.
Of course, much of this is centered around theory, modeling and lab tests. As mentioned in the source document, the proof is ultimately in long-term field testing. Well, multiviscosity 20W oils have been in wide use now for a long enough time that cars using them are into the hundreds of thousands of miles, and I haven't heard of a disproportionate number of lubrication-related failures on vehicles using 20W oils. While single UOA's certainly don't tell you much about engine wear, a compilation of all of the UOA's available may offer some insight. Someone on here's already done that, and 20W oils showed less wear. While not proof that they're better, given all of the variables involved, it certainly demonstrates that they protect adequately.
Simple question: where are the instances of specified oils not adequately protecting an engine? I've seen questions/anecdotes about one model of V-6 Honda. Anything else?
I just feel the need to repeat this as it seems people keep on asking what tests were done to prove the applicability of lighter oils.
Originally Posted By: fordoilfaq
Q. What durability tests have been done on this new grade of oil in excess of the warranty period?
A: Motorcraft 5W-20 was tested in the Arizona and Nevada desert heat, in Expeditions and Navigators loaded down to the max trailer towing capacity for up to 250,000 miles with extended drain intervals (15,000 miles). It was also tested in a fleet of taxis for stop-and-go testing and in the extreme colds of MinnesotA. In all cases, Motorcraft 5W-20 performed exceptionally with no oil-related failures.
That is really interesting! So if its not the heat from the turbo then why don't they use 20w?
Could it be the 20w will not stand the increased pressures and loads generated by the turbo?
Is the oil so marginal that Ford doesn't trust it to protect the engine properly?
As someone who understands engines, you know that Turbos and Diesels put far more pressure on oil than a normally aspirated gasoline engine, even if that engine is small.
My Mercedes takes xw30 or xw40 but both have to have minimum HTHS of 3.5. I believe the engineers when they came up with the spec for the engine. They could be wrong but it's the best information I have.
Toyota say their cars can now take 0w20. I believe the engineers when they came up with the spec for the engine. They could be wrong but it's the best information I have.
Again, what point are you making? All that I see is:
1) You believe people are recommending thin oils too much. Specifically Caterham, but he has a 5w50 in one of his vehicles.
2) You believe the government is restricting your choice.
Now, if you think that there are technical considerations that mean people shouldn't go by the indicators that folks like Caterham recommend, then let's enlighten the conversation by hearing what those are.
But just as it's wise to advise caution that a user might not know everything behind the actual spec a manufacturer gives when trying to go too thin, it is equally wise to caution that if Toyota recommend 0w20 in America, then going to 5w30 instead may miss some reasons why they spec it in America and not elsewhere.
Trav, perhaps you do the research and provide us answers instead of asking others to find the answers to your conjectures.
If I had that engine, I would go with 30 weight oil as it's recommended. It's probably the thinnest oil they could use.
You and others would presumably go for 40 weight as in the past it was unheard of to use 30 weight oil in a turbo right?
Originally Posted By: edhackett
Originally Posted By: CATERHAM
For a low VI 5W-20 2.6cP rated oil, that will happen with oil temp's of nominally 130C but at a typical 90C operating temp' that 5W-20 oil will have a HTHSV of about 7cP. I suspect the lightest 0W-20 oil available, Sustina with it's 229 VI likely has a HTHSV at 90C closer to 5.5cP if my experience with the oil is anything to go by. Still with a large enough safety margin to handle much higher oil temp's and possible fuel dilution. For a typical 5W-30 (HTHSV 3.1cP) bearing wiping will happen when oil temp's approach 140C under load and have a HTHSV at 90C of about 9cP.
With this in mind it would certainly make sence to have a HTHSV measured at 100C so that a PDS glace will tell you how much real safety margin one really has, largely negating the VI effect at typical operating temp's. But this won't likely happen.
Sub 2.6cP HTHSV oils have been available for a few years now in Japan and are already the FF on a few models made and imported from Japan. The Honda Insight and Fit are two such models.
Are your calculations above taking into consideration the temperature rise in the bearing? Shannow has also discussed this at length, it's in the 40-45C range. There's a reason HTHSV is measured at 150C.
An oil operating at 90C bulk temperature could easily be 130C in the bearing. 110C bulk could be in the 150C+ range.
Ed
With the maximum speed of oil flow through a crankshaft, up to 12 gallons per minute, the difference in oil temp's from input to out put is no where near 40-45C in most IC engines.
When oil temp's are given, it is bulk sump oil temperature that are referenced.
When Chrysler engineers state that 300F (149C) oil temp's running at full chat in an SR8, are not a problem with the spec' PU 0W/5W-40 HTHSV 3.68cP oil, do you think the oil temperature in the bearings is over 190C with no bearing wiping? I don't think so.
Providing the HTHSV measure at 150C makes sense for heavy 30wt, 40wt and heavier oils where the possibility of bulk oil temp's are approaching that temperature. An OEM can stipulate a minimum 3.5cP oil without making any reference to an oil's VI since bearing wiping will only occur at very high oil temp's where the effect of an oil's VI has almost no effect.
My point is that's not the case with 2.6cP oils and the even lighter oils to come. Bearing wiping will occur well below 150C and the difference between a low VI and a ultra high VI oil will lower the bearing wiping point even further; it is effectively a lighter oil. That's why I posited that providing a HTHSV measure at 100C (in addition to 150C as a traditional reference measure) would have real value in gauging the operational viscosities of 20wt and the new 16wt oils.
Absolutely not. Low pressure turbo's don't strain the engine like a high pressure unit. IIRC Saab had a almost high and a low pressure unit back in the 90's which ran 30w.
I can't figure out if you just trolling or if your understanding of motor oil and turbocharging architecture is really that limited? The Ford turbos have water jackets in the turbocharger bearing jackets, and it's done to prevent coking of the turbocharger on shutdown. How on earth is this related to oil viscosity? No offense Trav, but you've just gone off of the deep end trying to fit everything you read into a box that will confirm what you believe...
There was some error in the spec a few months ago when they said 5w20 GF4 as the current spec for a Ford turbo engine. AFAIK all 2012 3.5 ecoboost run 5w30.
Oil sites are claiming 30w for the 2012 Taurus 3.5 ecoboost.
I'm trying to wrap on head around the early film strength/thickness comments. Thanks
I guess I did a poor job of explaining this, so I'll try again. Mutligrade oils have different viscoelestic properties than monograde oils, because of their higher VI and polymer additives. That is, they're more elastic. So, a thinner oil, which is subjected to more pressure in a journal bearing, becomes thicker and supports larger loads, since it's viscosity increases exponentially (not linearly) with pressure. That's where the Barus Equation fits in.
If you're really interested, you can go to the library and pick this up for some pleasure reading: LINK
Obviously, you can get to a point where this effect will not be enough to overcome a lack of minimum oil film thickness, so there are limits to MOFT. That's why I said earlier that "it should" be adequate. It depends on the bearing clearances and the temperatures which the oil sees. It most applications though, a minimum hths of 2.4 or so seems to currently be the minimum across a broad range of engines. To go thinner than that, engine clearances will have to change.
Alternatively, you can always fall back to "what they do in Australia", and believing the gub'ment is trying to ruin our engines, as it seems popular around here...
Excellent post, thanks! Great points.
Originally Posted By: il_signore97
Caterham,
While I am not against thin oils by any means (there, I said it just to clear the air before I start!!!), I would like to point out a few of my own observations / thoughts.
I can agree that almost any passenger car on the road today can run on anything from 0W20 to 20W50 and live a reasonably long life. I can also agree that it is not smart to put 20W50 in a car driving across the street everyday, and that 0W20 on a race track may not be appropriate either. So, as you state, just meet the minimum oil pressure spec as listed in the service manual, right???
However, I see a few possible concerns with this. Firstly, this is not a "spec" it is a MINIMUM spec. I will use my old 2005 Nissan Altima (3.5 L V6 engine) as an example, since I have a lot of data and experience with it. The service manual clearly states that oil pressure must be HIGHER than these numbers. It says nothing about any maximum. It states rather clearly that when an engine cannot meet these minimum numbers with specified oil at full operating temperature (oil temp), then it needs an overhaul.
Using the same car with some numbers now... It states that the MIN oil pressure at full hot idle is 15 psi, and it gives a second test spec of MIN 45 psi at 2500 RPM. This obviously assumes that all healthy engines exceed these numbers on spec'd oil. With a MIN spec of 45 psi at 2500 RPM, how on earth would you not cause the oil pump to bypass at 7500 RPM??? There is no way that this could be true unless you use a 0W10 racing oil, in which case the minimum specs would not be met at the two test RPM's.
Using another vehicle, my tow vehicle (Chev Venture) has a relatively low bypass setting, and will still cause the bypass to open up at hot idle anytime above 4500 RPM. This is with a 3.1 cP HTHS synthetic oil, which is inline with what GM specs. This is also after long highway runs with my trailer, often engaging and remaining in 3rd gear to climb long uphill passes. 270,000 km so far and runs well.
My friend's Mercedes S500 with the spec'd 0W40 always went into bypass about 2500 RPM prior to hitting redline even after long highway runs, and this vehicle is equipped with a very large oil to water heat exchanger which maintains the oil temp at 90C once warmed up (it will make its way to 100+ C on the highway but returns to 90C with a bit of idling). This car has about 340,000 km on it at this point btw.
Are you suggesting that all of these vehicles that routinely enter oil pump bypass in daily use are not using the correct lubricant? Do you honestly think that the engineers that designed these engines don't know that they will enter pump bypass during normal operation? Ultimately, do you think that they did not already take that into account and ensure that the engine, despite being in bypass, still has ample flow of oil (i.e. more than the min required for proper lubrication, even though bypass is active)?
I can't say with any certaintly, but then again, neither can anyone else unless they happen to work on the engine development teams of a major manufacturer.
+1
Caterham, how did you estimate the viscosities when you said the following? Thanks.
You just don't get it do you? 20w is not spec for the 2012/2013 Taurus ecoboost (look it up, i did). My question is simple why the heck isn't it if the bearings are water cooled and have little impact on oil heating.
Troll?
I've said this on here before, but power density (along with usage profile) is key in all of this.
-It is why boosted engines spec heavier oil
-It is why engines like the BOSS 302 spec heavier oil
Euro marques like BMW and Mercedes spec heavier oil because the vehicles were designed to operate at continuous speeds far faster than what are obtainable here. This again ties in with power density, as a high HP V8 at 150Mph sustained is going to increase the sump temperature. And while coolers are employed to keep oil temperatures in check, a heavier viscosity is ultimately still spec'd to provide adequate protection under these conditions.
Originally Posted By: MarkStock
Yes 1 choice of oil is stated because of CAFE. I agree and have said this before. CAFE's objective is to increase fuel efficiency and they are saying to the manufacturers that those fuel efficiency increases will only be realized if people actually use the lighter oil. They don't want to give the credits unless steps are taken by manufacturers to encourage the use of the oil they are using to claim the credits.
I'm not sure what your problem with me is, you're admitting its CAFE, so we agree. Let me say it once again for the record, all I'm asking for is a choice. Let me decide what's best, not Uncle Sam. I really don't care about CAFE credits. I care about what is best for my engine, but still want to maintain a warranty. I don't have that choice. You keep quoting Ford from 2004, how are they today with oil related warranty issues? Have any facts what they'd say if 30 grade oil was used in a 20 grade application and the engine failed? I want to know about now, not 2004. I don't want to hire F. Lee Bailey and The Dream Team to go to battle for me if I have a problem.
Ford did state in your article all applications from 2004 on would be using 20 grade oil. They made the statement I didn't. A bold but stupid contradictory statement wouldn't you say? They should have left that comment out altogether, it would have given them more credibility. I honestly think that article was a lot of hype to deal with concerned consumers, so they published a report to help comfort them. I'm not denying they did the testing, maybe just embellished it a bit. For the record I'm a Ford fan.
Quote:Q. Why not put 5W-20 in all the motors to make it more standardized for the technician?
A. 5W-20 is the oil of the future, 100% of factory fills will be 5W-20 by 2004.
