Patman
Staff member
Originally Posted by batook
Originally Posted by Gokhan
BOQI is great! It can distinguish between PAO, GTL, Group III, and Group II. Everyone should benefit from this knowledge. What other magical touchstone can tell you what base oil is inside a motor oil? If you don't believe it, that's fine -- I won't hold it against you.
I'm not too familiar with BOQI and how it can be used to distinguish between the different base oil types. If you wouldn't mind, can you please explain a little further how the BOQI can be used to determine this? Also, how did you find out the BOQI of the M1 0W-20 EP? I don't see it listed on their product data sheet; is it something you have to request from them?
They won't give you that info, because it isn't a real thing. It's a made up index by Gokhan.
