The coolant to oil heat exchanges are dual purpose. They help warm the oil up faster, and they also help keep the oil cool when at full operating temperature. The coolant that feeds the oil cooler is coming basically from the cold side of the radiator, which will be cooler than what the coolant temperature is in the engine that's controlled by the thermostat.There is a oil/coolant temperature exchange device, but since the coolant increases temperature before the oil the exchange is to warm the oil. It is as simple as to follow that device on the coolant side and see what the coolant thermostat is set for.
Hi @Shel_B , in order to facilitate a reasonable discussion, can you please cite your source(s) for the claim above?I recall reading somewhere that some/many/all engines designed to run thinner oils (0W-16/20) operate at lower oil temps in order to maintain greater film thickness and provide better protection. Is my memory accurate, at least to some degree?
His first sentence answers your question ! he doesn't remember ?Hi @Shel_B , in order to facilitate a reasonable discussion, can you please cite your source(s) for the claim above?
Operating at lower temperatures goes against lowering emissions, not very popular these days.I recall reading somewhere that some/many/all engines designed to run thinner oils (0W-16/20) operate at lower oil temps in order to maintain greater film thickness and provide better protection. Is my memory accurate, at least to some degree?
Sometimes poking and prodding can help to jog one's memory.His first sentence answers your question ! he doesn't remember ?
I often wonder if these "i recall statements " are self induced hypothesis ?Sometimes poking and prodding can help to jog one's memory.
Unless you have DI. I see some newer cars are going to double injection now DI and Port injection combined.0w20 is a very robust oil. stays in viscosity protects and performs very well.
Whether an oil "stays in viscosity" is entirely dependent on engine design and operating conditions, as well as the specific brand formulation. It has nothing to do with being a 20-grade.0w20 is a very robust oil. stays in viscosity protects and performs very well.
