cheesepuffs2
- Joined
- Jun 3, 2021
- Messages
- 1,392
When did I imply that most people understand the relationship between viscosity, film thickness and engine wear? My point was the opposite, that the vast majority of car owners have their heads in the sand, yet do not experience excessive engine wear, displaying that bumping up in reaction to this boogeyman issue is pointless.Most people taking their car to Iffy Lube don't even understand multi-viscosity oil or even what the "W" grade really means. How do you think they are going to understand the relationship between viscosity, film thickness and engine wear?
Most "thickies" here are overly concerned owners of mundane engines that are spending time and energy trying to figure out a solution to a problem that doesn't exist. Stressing that if they don't go thicker than what the manual says that they'll experience excess engine wear. The reality is that cars end up in the junkyard due to just about every reason aside from a hair more bearing wear, if that's even occurring at all, due to thinner oil.Nobody here has claimed that using the specified oil is going to result in an "engine failure". This is something the thinnie fans seem to latch onto whenever someone simply says that thicker oil gives more wear protection. It's funny.
You are completely inferring something from my response other than what I wrote.Ford speds 5W-50 for track focused Mustangs. All Coyotes have a coolant-to-oil cooler. They now spec 5W-30 for normal street use. So the grade increase is not for the reason you think. If it was a lack of oil cooling, they would have made the oil cooler better 10 years ago and keep that 5W-20 for CAFE credits.
I never equated your track use 20 grade example to oil grade specified for the Coyote. You gave two different examples, not even specifing what kind of car had the issue using 20 grade on track. I already said, I don't really care about the Mustang example, because that isn't a direct comparison the generalizations that are made on this forum. That's one situation for an OEM to sort out, and they did. Cool. Next.
Again, you are entirely missing the point. My whole basis of this is that people recommend going thick with no ceiling on at what point it may become a detriment.Many that understand it will say a grade up will be beneficial. Who here has claimed that you need to run 20W-60 to get better engine protection?
Have we beaten this horse enough yet?Yeah, they chose wrong ... they chose too thin and instead thought they could push the envelope to get CAFE credits. It probably cost them some warranty work and more money over the years than they saved in CAFE credits. Why else would they bump up the specified viscosity in the USA?
I've referenced multiple times now how this forum is mostly comprised of basic transportation applications. You're grasping for a rebuttal to an argument I never made.Yes they should for track use ... maybe even go with 5W-50 as Ford specs for their track-pack cars. As I already said, 5W-30 is good for even hard street use.
