Reading comments here, it obviously comes up that thicker oil does a better job of separating two parts from contacting one another, which reduces wear. This is often stated as if "more is better" with no real cap on how thick is too thick until there are diminishing returns.
My thought (not my true belief) is this:
If thicker is always better until any circumstance, well, we know that a 5W-20 grade oil as say 5 degrees F is many times thicker than say a 5W-30 grade is at 212 degrees. Aside from the question of cold cranking, and assuming the oil pumps quickly enough to avoid damaging the engine since it is a 5W, then wouldn't a cold oil (that's still within temperature range for the grade) prevent wear the best, even better than nearly any oil at it's full operating temp?
