Four bolts per main cap. Full girdle construction. inserted main caps.
Those inserts are cast into the girdle.
This is racing block technology in a production engine. Note how the oil drainback is routed around the crank to reduce windage.
The windage tray design contributes a non-trivial amount of bottom end stiffness also.
On Cummins engines, we use a "bedplate" which looks like a windage tray. But its purpose is structural for bottom end stiffening, not for oil control per se.
This toyota engine has a similar approach however the shape and thickness of the plate suggest it's more for windage and the structural contribution is secondary. It's just not very stiff by itself. But when you add that to the girdle design and such, it's a really really beefy bottom end, far more so than even the best of the classic muscle car engines.
As it should be, it's making a lot more power per liter.
