I have gone down this rabbit hole on another
thread concerning the V35A. Here are my take-aways...
1. It's not a viscosity issue. There are threads on IH8MUD where there have been failures in other countries where they use Xw30, Xw40 and even Xw50.
2. It doesn't matter if it's produced in the US or Japan, if it's gonna go, then it'll go.
3. Hybrid models have the same engine and are failing as well. Unfortunately they get hosed and most are just getting short blocks that are hand assembled in a Toyota dealer shop by a technician that you hope is mildly versed in engine assembly. Also, Toyota's excuse for not including hybrids is that the hybrid motor allows for propulsion to get safely off the road in the event of failure. So far, every hybrid engine failure owner has said that once the engine died, so did the hybrid system.
4. Oil pressure specs are incredibly low on this engine. Idle spec is 4psi or higher, 2500rpm is 26psi or higher. That idle speed pressure seems wild. Also note that 26psi isn't necessarily bad, but adding 10-15psi of boost is a lot of additional load at 2500rpm might not be so great. Especially since the trend is to keep these engines as low in the rpm as possible as often as possible. So if your engine is already teetering on the low end of pressure specs, things can go south quick.
5. There has been no coloration between oil change history and failure rates. What I mean is that even people who are diligent or that did break-in oil changes like Lake Speed and then change oil at 5k or even 3k OCI's have still had failures.
6. Comparing simply the specs (see this
post), the 3.5 ecoboost has TIGHTER main bearing clearances and recommends 5w30. But it's oil pressure specs are higher as well. Not that I'm saying 5w30 is the answer, but the V35A certainly doesn't qualify as have extremely tight tolerances.
My point is that the debris excuse is just that, an excuse for a problem that Toyota hasn't figured out how to fix economically. There is a major design flaw, bearing oil retention issue and/or an oil delivery issue, but we'll never truly know. Now with the recent updates to the recall they are pulling a fast one like GM and claiming they can use "Inspection Software" to evaluate if #1 Main Bearing has abnormal wear. How the heck does software tell you if you have a hardware problem? Only thing I can see is oil pressure monitoring and knock events. But deciphering that to pin point a bad bearing is a bit of a reach IMO.
The Toyota diehards still defend Toyota somehow. I would imagine their tone would change if it happened to them 400+ miles away from home towing their camper. Some of the stories I have read about when and where the failure happened as well as how everything was handled have been pretty horrible. Which is part of the reason I didn't get a new Tundra last year. Besides the engine issue, the overall quality of the 22+ Tundra has not been very impressive in the ones I test drove.
