Yea, those OLM are junk, just ask Patman. He went to almost 150% on his Vette and the oil was still OK.
No, that isn't normal. On some GM models (can't remember which), the OLM light is reset by pressing the accelerator pedal down completely 3 times, within 5 secs, then starting the car. You must have inadvertently reset the OLM without realizing it, as the OLM should NEVER go more than 12500 miles between an oil change.quote:
I reset the dummy light OLM in my Buick Regal LS the first time I changed the oil (it wasn't on, I just reset it since you're supposed to when you change the oil). It's now been ~30,000 miles and ~4 oil changes without resetting it, and it has not come on. If I was a typical uninformed consumer...
Yes, I did ignore Dyson's comments since I felt he was a competitor with Blackstone's which performed the test. I also felt that Blackstone's would have made a stronger suggestion if any damage was occurring to the engine. Instead they said, and I quote, "Universal averages show typical wear metals for an oil from this type of engine after about 5,095 miles run on the oil" end quote. Also "No gas or antifreeze found" did not set off any alarms as to the oils inability to "cope" with the effects of fuel loading.quote:
This UOA report?
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=002940;p=2
I think you failed to understand or ignored Terry Dyson’s comments.
This oil sample showed high lead due to the corrosive effects of running an oil beyond the ability of the anti-oxidant additives to protect against the effects of fuel loading. The level of insoluables is a supporting factor.
Suggest including a TBN and particle count next time a 12k OCI is posted to give a truer picture of the condition of the oil.
The name of the game is not running a motor oil to the oil's physical limits - it's keeping a lubricating fluid, with fully functional additives, pumping thru the engine!
Posts: 1211 | From: Wisconsin | Registered: Sep 2003 | IP: Logged |
Yeah, I know, I've just never paid much attention to it until last night. The light is fine, and since resetting it means sitting there with the ignition on but the engine not running and pressing the gas petal 3 times, I'm sure I haven't reset it.quote:
The change oil light should come on briefly when the vehicle is first started. If not, it may be burned out.
