With the LC added, your analysis results are pretty much useless. I wouldn't trust them at all for the purpose of judging the effectiveness of the Oil Life Monitor system. Furthermore, the LC may invalidate the effectiveness of the OLM for determining when to change your oil. You are adding factors to the equation that are not included in the OLM system. Why do you need the LC anyway? What is it gaining you? Especially in a leased vehicle, your oil maintenance practices are puzzling to me.
TripleSe7en, why is the OLM so bad in your judgment? I know of maintenance-oblivious GM owners (1 truck, 3 different cars) who only change oil based on the OLM and regularly go 5000-10000 miles between changes and they have had zero lubrication-related issues on conventional motor oil in over 100k miles. I don't see why it's so bad. Looks to me like it works pretty darn well. Maintenance costs are reduced, the engines last just fine, less toxic stuff gets added to the environment, and owners know how to properly maintain their engine oil. Everything I read about it makes it sound like a well-engineered system with consideration for many factors that affect oil service life, and combined with the fact that I have never heard of anybody having oil-related engine problems while following the OLM, I can only conclude that the system is working well. Not many people keep their cars beyond 300k miles, and if they do, they've probably fixed so many other things that the replacement engine cost would have been a drop in the bucket. If there is a failure here, it may be that GM needs to set expectations about what to expect from your engine by following the OLM. You have presumed it will cause problems without any evidence of such, and I am assuming it won't cause any problems. You know my reasoning, and I'm interested in hearing yours.
[ December 05, 2005, 05:03 PM: Message edited by: J. A. Rizzo ]
