2004 Buick Lucerne, 125K miles. The driver's side headlight assembly was broken out and the hood was bent due to a tweaker breaking into the dealership and driving a car thru the showroom wall. On the way out he clipped four cars in the lot, including this one. I went into the dealership with every intention of buying it and attempting a repair myself, and after examining it in person I was convinced I could do it. Then I took it on a test drive.
The first annoyance was that the headliner was sagging and rubbing against the top of my head, but that's nothing a couple of magnets can't fix. Unfortunately after about a block I glanced down to check my speed and that's when I noticed the speedometer and tach weren't working. I assume the fuel gauge wasn't either because it was well below empty. Oddly enough the temp gauge was dead in the middle. I did a loop around the block and asked the salesman if they might be willing to check out the gauge cluster for something simple like fuses or a disconnected wire. And then the beeping began and the red light appeared on the dash. It turns out that the temp gauge actually did work and was now completely pinned on H with a red light beside it.
I shut it off, lifted the hood and determined the electric fan was running. You could hear the coolant gurgling thru the hoses. I thought the salesman started to remove the radiator cap but I cautioned him. He said he was checking to see if it felt hot and apparently it didn't, so maybe the issue is just a stuck thermostat.
I told him I still might be interested if the issue with the gauges and he overheating can be resolved. He said he would try to get a tech to check it out, but so far he hasn't called. We shall see...
