quote:
Reducing friction isn't just for fuel economy, but [for] reducing wear. I'd guess that some oils, maybe Redline for instance, would have higher viscosity oils that are as fuel efficient as another brand's lower viscosity oils. This would mean RL's Cf is lower. So in theory you could have a GF-4 oil that met the fuel efficient spec but could still protect very well bc it would still be a higher viscosity. Any thoughts?
You can't destroy the laws of physics. Thicker fluids mean higher energy losses, but also means thicker hydrodynamic films. And this is where the short term research is going; add a thicker fluid with a very good VI and shear characteristic to a thinner PAO, and use the appropriate protection and performance additives.
Now once more, I think you and others have confused Anti-Wear (AW) additives with friction reducers (FM's). Now FM's can mean friction reduction across the board, or friction that changes, depending on the relative speed between surfaces.
Friction reducers work by depositing sacrifical whiskers that are lopped off, much like a mower does to grass, keeping the metal separated mostly during the hydrodynamic or mixed lubrication regime. Friction reducers can also reduce the shearing action of the fluid, thus leading to better MPG and less energy dissipated in the oil.
Anti-Wear additives lay down a film that becomes plastic under pressure, preventing the surfaces from actually touching during the boundary lubrication regime, I.E., when there is barely an oil film or when the contact pressure is so high, the oil film is squeezed out (film strength exceeded by the localized pressure).
An Extreme Pressure (EP) additive not only forms a film, but chemically reacts with the first few micrometers of metal surface to form a sacrificial film such that the sacrificial film is allowed to SHEAR, rather than having the metal surfaces gouge, gall or shear against each other.
FM's and AW additives are used in engines oils and hydraulic fluids.
EP, AW, and FM additives are used in MT and differential gear lubes, with the EP additives being the predominant additive.
[ September 26, 2005, 09:54 PM: Message edited by: MolaKule ]
