Synthetic Oils With Lowest VII's ?
Drained the hot Amsoil 5w30 Signature early this morning on the handed down vehicle outdoors at a balmy -23c/-10f.
Refilled with Amsoil 10w30 Signature along with a Mopar filter; after it sat for a good 14 hrs outdoors, cranking up with the new oil in a couple degrees colder ambient made absolutely no difference in starter speed or oil pressure come up.
@Gokhan I read though your list linked here: https://www.bobistheoilguy.com/foru...erature-full-shear-viscosity#Post5133467
Do you have any info on the VII on Rotella Gas Truck 0w-20 specifically? There is a huge difference between Rotella Gas Truck 5w20 (being among the lowest VII) and Rotella Gas Truck 5w30 (being among the highest VII) among those listed on your spreadsheet.
I am curious to know where Rotella Gas Truck 0w20 stands comparatively speaking.
The problem with Shell is that they don't provide HTHS in their data sheets, which makes my VII and base-oil viscosity estimates a guesswork.
I played around with it to see which HTHS value is more reasonable. To keep things in line for the base-oil viscosity index, which is actually not a reliable calculation because the VII type and how the VII scales the viscosity with the temperature is unknown (I assume a constant scaling, which is usually reasonable for OCP VII), I had to increase HTHS for Rotella Gas Truck 5w30 to 3.2 cP. So, perhaps Rotella Gas Truck 5w30 indeed has a high HTHS by design. This also decreases the VII content estimate for it and makes it more reasonable.
If someone can contact Shell and find out the actual HTHS values for Rotella Gas Truck 0w20, 5W-20, and 5w30, I can run a more reliable calculation. If Rotella Gas Truck 5w30 indeed has HTHS = 3.2 cP, this would be a major, major verification for my calculation, as estimating HTHS goes a step beyond the original scope of my calculation.
Meanwhile, these are my latest estimates:
Estimated VII content and base-oil viscosity for selected oils
Gokhan - that is an excellent table for comparing different oil properties before one delves into the finer points of AW, location specific CCS/MRV etc.
Thank you for the time & effort.
