dragboat: Go by your local VW dealer and pick up a quart. It's Group III and smells like oil to me.
Johnny, have you ever smelled the regular Syntec? It doesn't smell like oil at all. It has a very sweet odor, almost detergent like. Mobil 1 doesn't smell like oil either. It has a plastic-like odor.quote:
They must have worked on it some ?quote:
Originally posted by Dr. T:
Found that the NEW bottles of Syntec in only the 0-30 grade are labelled as "Made in Germany" for Castrol N.A. Found that was interesting. It's also listed as being ACEA A1/B1/A3/B3/A4/B4 and M-B 229.1 and 229.3, BMW Long-Life 01, VW 505 and Porsche approved.
The stuff smells slightly different than the other grades of Syntec and seems "green" in color. Is this a different beast altogether from the other Syntecs?
You guys are just going to have to all move north to keep me company up here!quote:
Originally posted by Chris Jefferson:
Who wants to bet $20 that Castrol, N.A. ONLY sells this oil in Canada? Well never see it here in good ole' "know-it-all", "we're the best period", and "always right" U.S. of A! Sorry for the sarcasm, had to let it out.
What about the "made in USA" Syntec 0w30 though? It's group 3, isn't it? Looking at the specs on it's bottles here though, it's not impressive, it doesn't show all the ones that the made in Germany 0w30 shows.quote:
Originally posted by G-Man II:
Because the Castrol synthetics made in Germany are PAO based. Plus, from what I've read elsewhere, it's virtually impossible to make a 0wXX oil from a Group III base oil, the one exception being a wax isomerate like Shell's XHVI or ExxonMobil's ExxSyn.quote:
Found at a local newly opened Wal-Mart in Toronto. Why do you think it's PAO based?
It's been reported than when Castrol first went to Group III, the base oil they used was Shell's XHVI. So I suppose it's possible that the 0w30 made in the US could still use that base oil. I would suspect, however, that Castrol ran the numbers and figured it was cheaper in the long run to import the European 0w30 than to keep producing the Group III product here. Plus, the European 0w30 has better numbers and can come closer to competing with Mobil 1 0w30 than the Group III product could.quote:
quote:
Castrol FORMULA SLX SAE 0w30 - the intelligent Eco Vollsynthese
Performance classes: API SL/CF - ACEA A3/B3/B4 - exceeds 503 01 (9/99) approved after VOLKSWAGEN, 502 00 and 505 00 (1/97) - MT 229,3 BMWS (Longlife-01)
Castrol FORMULA SLX is the intelligent Eco full synthesis. By its innovative molecular structure and its trend-setting additive technology it reacts flexibly to each driving conditions. Thus it protects the engine reliably in all phases of the most diverse demands, which can occur in the daily employment and with the different styles of driving:
· with many cold weather startings and short distances
· with frequent stop and Go-traffic
· with long full power distances
· with extreme heat or cold weather
Castrol FORMULA SLX provides by its outstanding lubricating and flow characteristic for a reliable and persistent protection of the engine .
Castrol FORMUL A SLX fulfills the substantially higher requirements, which place the new long oil change intervals against engine oils by its special development. It reduces besides the oil consumption.
Castrol FORMULA SLX secures high engine cleanliness and prevents the formation of deposits - important for a durable and problem-free function of the engine.
Castrol FORMULA SLX saves constantly and continuously fuel , during the gesam ten period of the oil change intervals.
I've read on the global Castrol website that Castrol does have blending facilities in the US, though no refineries. They do blend and bottle their own oil in the US.quote:
Originally posted by GeorgeCLS:
Just as a matter of discussion regarding Castrol oil sources and production. Has anyone here in the U.S. ever driven by a Castrol refinery? Right, there are none... Every drop of Castrol product produced here in the U.S. is made and bottled by someone other than Castrol for Castrol. So, yes, Castrol products may indeed come from just about anywhere, made by just about anyone from just about any base stocks!!
It would certainly be an interesting project for someone to undertake although it would take CIA level undercove to define just who is making what oil and where they are blended for Castrol. It would be a most enlightening discovery paper indeed!
What are the technical specs on this oil though? I couldn't find anything in a search on the Castrol website Ken posted above.quote:
