Quote:
if the egr was so great why do no racing teams that i am aware of use it? last time i was at the 24 hours of sebring i saw no engines with egr.
last time i was at moroso drag strip i saw no cars with ADDED egr. some had it from the factory, but no one actually added it, and a significant ammount of people removed it.
Well, I don't know how practical it is in racing when you can just dose the charge with fuel to contain detonation. There you're looking for max output, not peak efficiency. 500 miles/24hours/3 seasons to a refresh is a little different than 150k miles of integrity
..but I do imagine that there is or has been research into ultra high compression gassers using egr to cut the intake charge with inert material. I also imagine that they've been confronted with "conflicting complications" in doing so. I've watched Chrysler's emission tech films (in the early 70's) where they showed the catalytic converter and marveled at how it cleaned up the exhaust. They then added that "unfortunately, it requires unleaded fuel to remain effective". That was one MAJOR obstacle to overcome ..but it occurred.
Sometimes there are things that are effective ..but are just not practical in the current confines of the market. The end user has to be (virtually) eliminated from the equation and can be required to do no more than get fuel and perform the minimal routine maintenance. The device/vehicle must jump through all the hoops for a "consumer ready" product. This narrows the support streams to those that are mass marketed and have to be compatible with everyone else in the market.
Look what Ford had to do to get to use 5w-20 for their EPA/CAFE testing. They had to bring a 5w-20 oil to market where one wasn't widely available. They knew that they could run it. GM knew that they could run it ..so did DC, Toy, ..everyone. They knew this due to common shearing of older 5w-30 oils. So it wasn't rocket science to use this stuff. It was, however, totally dependent upon Ford's profit model that resided totally in larger gas guzzlers and their distinct need for every spare .01'th of mpg on the economy cycle. Other manufacturers were not so heavily weighted in the upper end offerings and didn't see the cost effectiveness of bringing a new oil to market (widely available) just for the efficiency of it.
Very little room to navigate on innovation ..at least at reasonable cost. Now, and for a pretty long time, it's been sorta reversed. The government just modifies the obstacle course as required and the manufacturers have to figure how to jump through the hoops. They often "can't get there from here"
