MiT Develops New Aircraft Wing.
ON, Canada eh?
https://scitechdaily.com/mit-engineers-demonstrate-a-new-kind-of-airplane-wing/
Quote
A team of engineers has built and tested a radically new kind of airplane wing, assembled from hundreds of tiny identical pieces. The wing can change shape to control the plane's flight, and could provide a significant boost in aircraft production, flight, and maintenance efficiency, the researchers say.
The new approach to wing construction could afford greater flexibility in the design and manufacturing of future aircraft. The new wing design was tested in a NASA wind tunnel and is described today in a paper in the journal Smart Materials and Structures, co-authored by research engineer Nicholas Cramer at NASA Ames in California; MIT alumnus Kenneth Cheung SM '07 PhD '12, now at NASA Ames; Benjamin Jenett, a graduate student in MIT's Center for Bits and Atoms; and eight others.
Instead of requiring separate movable surfaces such as ailerons to control the roll and pitch of the plane, as conventional wings do, the new assembly system makes it possible to deform the whole wing, or parts of it, by incorporating a mix of stiff and flexible components in its structure. The tiny subassemblies, which are bolted together to form an open, lightweight lattice framework, are then covered with a thin layer of similar polymer material as the framework.
The result is a wing that is much lighter, and thus much more energy efficient, than those with conventional designs, whether made from metal or composites, the researchers say. Because the structure, comprising thousands of tiny triangles of matchstick-like struts, is composed mostly of empty space, it forms a mechanical "metamaterial" that combines the structural stiffness of a rubber-like polymer and the extreme lightness and low density of an aerogel.
Jenett explains that for each of the phases of a flight — takeoff and landing, cruising, maneuvering and so on — each has its own, different set of optimal wing parameters, so a conventional wing is necessarily a compromise that is not optimized for any of these, and therefore sacrifices efficiency. A wing that is constantly deformable could provide a much better approximation of the best configuration for each stage.
While it would be possible to include motors and cables to produce the forces needed to deform the wings, the team has taken this a step further and designed a system that automatically responds to changes in its aerodynamic loading conditions by shifting its shape — a sort of self-adjusting, passive wing-reconfiguration process.
"We're able to gain efficiency by matching the shape to the loads at different angles of attack," says Cramer, the paper's lead author. "We're able to produce the exact same behavior you would do actively, but we did it passively."
This is all accomplished by the careful design of the relative positions of struts with different amounts of flexibility or stiffness, designed so that the wing, or sections of it, bend in specific ways in response to particular kinds of stresses.
Cheung and others demonstrated the basic underlying principle a few years ago, producing a wing about a meter long, comparable to the size of typical remote-controlled model aircraft. The new version, about five times as long, is comparable in size to the wing of a real single-seater plane and could be easy to manufacture.
While this version was hand-assembled by a team of graduate students, the repetitive process is designed to be easily accomplished by a swarm of small, simple autonomous assembly robots. The design and testing of the robotic assembly system is the subject of an upcoming paper, Jenett says.
The individual parts for the previous wing were cut using a waterjet system, and it took several minutes to make each part, Jenett says. The new system uses injection molding with polyethylene resin in a complex 3-D mold, and produces each part — essentially a hollow cube made up of matchstick-size struts along each edge — in just 17 seconds, he says, which brings it a long way closer to scalable production levels.
"Now we have a manufacturing method," he says. While there's an upfront investment in tooling, once that's done, "the parts are cheap," he says. "We have boxes and boxes of them, all the same."
The resulting lattice, he says, has a density of 5.6 kilograms per cubic meter. By way of comparison, rubber has a density of about 1,500 kilograms per cubic meter. "They have the same stiffness, but ours has less than roughly one-thousandth of the density," Jenett says.
Because the overall configuration of the wing or other structure is built up from tiny subunits, it really doesn't matter what the shape is. "You can make any geometry you want," he says. "The fact that most aircraft are the same shape" — essentially a tube with wings — "is because of expense. It's not always the most efficient shape." But massive investments in design, tooling, and production processes make it easier to stay with long-established configurations.
Studies have shown that an integrated body and wing structure could be far more efficient for many applications, he says, and with this system those could be easily built, tested, modified, and retested.
"The research shows promise for reducing cost and increasing the performance for large, light weight, stiff structures," says Daniel Campbell, a structures researcher at Aurora Flight Sciences, a Boeing company, who was not involved in this research. "Most promising near-term applications are structural applications for airships and space-based structures, such as antennas."
The new wing was designed to be as large as could be accommodated in NASA's high-speed wind tunnel at Langley Research Center, where it performed even a bit better than predicted, Jenett says.
The same system could be used to make other structures as well, Jenett says, including the wing-like blades of wind turbines, where the ability to do on-site assembly could avoid the problems of transporting ever-longer blades. Similar assemblies are being developed to build space structures, and could eventually be useful for bridges and other high performance structures.
The team included researchers at Cornell University, the University of California at Berkeley at Santa Cruz, NASA Langley Research Center, Kaunas University of Technology in Lithuania, and Qualified Technical Services, Inc., in Moffett Field, California. The work was supported by NASA ARMD Convergent Aeronautics Solutions Program (MADCAT Project), and the MIT Center for Bits and Atoms.
Publication: Nicholas B Cramer, et al., "Elastic shape morphing of ultralight structures by programmable assembly," Smart Material and Structures
[Linked Image]
[Linked Image]
Originally Posted by ragtoplvr
Call the Wright Brothers, their wing warping is back.
Yes, that's for sure. How linear the technique will be, is questionable, specially with high angles of attack to the airflow...... like in take-offs & windshear. Can anyone say...... Boeing 737 MAX? Used on fighter planes, it'll be a zoo, even with all the high speed electronic adjustments. Can anyone say...... Boeing 737 MAX?
This just in: A boffin at MIT has invented a "tele-phone," a hand-held "instrument" for personal communication that does not require batteries, radio signals or even push buttons.
"It doesn't even require a rotary dial!" enthused inventor Gyro Gearloose, a professional MIT student, referring to the first 50 of his many failures. When asked what a rotary dial is, Gearloose declined to answer, citing proprietary secrets.
"You simply pick up this object, attached by a copper wire wrapped in cloth insulation to the base of my tele-phone, put it to your ear, place this short funnel at the top of the tele-phone's stalk in front of your mouth and say "Hello, Central, get me Wright Brothers 1903, or whatever number you wish, and in a few moments you'll be speaking to the party at the other end."
Gearloose predicts his invention will end unemployment through his tele-phone company's hiring of 190 million circuit switchers he termed "tele-phone operators."
Yep, MIT's tenured faculty are somehow more advanced in their ability to design wings than the guys at Boeing or Airbus, and let's forget that little American shop known as DARPA.
This post reminds me of an old April Fool's Day column written by Peter Garrison for "Flying".
He describes a similar type of wing, except it's so efficient that it can generate its own thrust and must therefore leave the air in its wake cooler, since the energy must come from somewhere, after all.
This is the beginning of the giveaway, which is fully revealed when it's said that the pilot is actually directly controlling this magic wing with his mind.
IOW, this is not a new idea, nor is it a practical one.
Someday?
I'm reminded of a book subtitled Where's my Xxxxxxx Jetpack?, which I got from the library and found quite interesting, especially since I saw a guy fly one in Cali way back in the sixties. Still nothing you can buy and operate and probably never will be.
IOW, maybe never. Some ideas that look promising on the surface have irresolvable problems, like jet packs and maybe this idea, and at this point it remains an idea and not a wing.
It's really interesting when one spends time looking at the drag curves of a wing in various conditions. At zero lift, the Cd is very low, then as the wing is asked to provide more and more lift, angle of attack increases, and unsurprisingly, drag increases. With any wing, of any design and of any reasonable shape, the lift/drag curves are rather similar. Many other factors come into play, including the requirement for transonic flight.
But once again, claims of "far more efficient" just won't come to be. We've done a great job minimizing drag over the last 5 human generations of flight.
The idea that a round fuselage is a drag producing monster is simply wrong. They are very streamlined and the airflow path along a fuselage is not perfectly linear from front to back, but instead starts at the bottom front and ends up at the top aft. Tracing a path that is more teardrop shaped than might at first be expected.
The idea that a blended wing to fuselage shape somehow can lead to massive improvements in aerodynamics (and efficiency) has been around for a long time. It may work well on a stealth bomber that requires no significant fuselage volume. But when conventional aircraft designers start cramming passengers into areas large enough to be comfortable, the frontal area increases to epic proportions.
And what happens to a wing with all kinds of electronics controlling each of the small sections when it gets hit with even a small lightning strike? One hit and it comes falling out of the air tumbling totally out of control like a duck that just got blasted with a 12 gauge shotgun. No thanks.
Years ago I was at Rostraver Airport and saw a nice new twin turbo Cessna with a new design of composite type wing being flown nation wide by a beautiful young woman delivering packages all across the US. And a few months later someone told me that she got hit by lightning and it caught fire and she went into a mountain in the Rocky Mountains. I guess slamming into a mountain is a better way to go than getting burnt to death. But if that composite wing could of withstood lightning strikes she would not have gone down.
Sometimes something that looks good in the lab has a long way to go before it really can perform in the real world.
