"two cycle oil is mainly solvents, not much for zinc of other EP additives"
true, I was thinking as an alternative to kerosine or atf as a pre oil change oil flush, not to run as a motor oil. Could the high solvents work as well as some of the other cans of elixiour out there? I'd be more comfortable with the tcw3 than some of the stuff I've heard about? at least I know its' got some lube in it?
