Thick oil wanted for 1991 4.3L GM V6
South Dakota
1991 Chevrolet K1500, 4.3 V6. I want to run a thicker oil due to oil burning caused by bad valve guides. Truck is a beater but runs decent; gets me from point A to point B. Brand doesn’t matter. I didn’t have any success in finding a cheap 5W/40. Wondering if I should run a 10W/40 or just run 3 quarts 5W/30 and 2 quarts of 15W/40. Please advise.
For an oil burner-beater, use whatever you can physically pour in it. A conventional 10w40 would be my choice. If you have the combination you’ve mentioned, that will work great also. Are you certain it’s worn guides? Valve stem seals is typically the issue with the 4.3 and really inexpensive. Probably less expensive than 5 quarts of oil.
https://www.amazon.com/Replacement-...e5-8271-6689b04c73f7&pd_rd_i=B0BXTFQM6S&psc=1
Yeah, after 5 or 6 years of owning it, I had the stem seals replaced but my mechanic said the valve guides were worn. Not really worth replacing. Roughly a $1500-$2000 vehicle. Just want to slow down the oil burning.
  • Like
Reactions: wlk
Did he use just umbrella type seals or a combination of factory o-ring and umbrellas? If just either it won’t stop the oil consumption. We had a fleet of them back in the early nineties.
I started using 15W-40 in all my vehicles, so far no regrets. Dual-rated HDEO 15W40 is often the cheapest oil on the shelves anyways. Carolina climate allows that grade though.
If the vehicle were mine, I'd try any cheap 15W-40 and see how it improves things. Sure, most 15W-40 are diesel oils, but it won't make any difference in your (old) gas engine.
Start with 10W40 with a jug of 15W40 for top up’s - if that slows the consumption you could run 15W40 in the summer …
  • Like
Reactions: wlk
Would this be to expensive?
$22.97 per 5 quart jug. It used to be $18.97, but inflation happened. It uses GTL base stock, so it's actually really high quality oil.
It's still February in South Dakota... I'd stick to a 5W-30 for the next few months. Once the cold nights have passed then give the 10W/15W-40 a try.
I used to run 10W-40 in a Honda Accord when Iived in Wyoming and those cold winter starts were brutal.
I'd skip the Euro 40s they are on the thin side. Like others...HD 15W40.
Starting temps is the main concern when choosing an oil the XW part, South Dakota winters can get a bit brisk. The 4.3 is a good engine try a 15W-40 for the summer. Thicker oil may or may not help but it is fine for use when the starting temps are a match for the Wratings..
How much oil do you burn in 1000 Miles of Driving?
