- Joined
- Nov 29, 2023
- Messages
- 549
Summer time Kohler motor oil !
It works just fine in winter. Most trucks in the US run 15W-40 in Winter, and some run even cheaper stuff than Delvac 1300.
I change twice a year and have some old PPE 0W40 I use duringIt works just fine in winter. Most trucks in the US run 15W-40 in Winter, and some run even cheaper stuff than Delvac 1300.
This is BITOG, that's what we do, LOL.Overthinking this
If it's excessive, it's not too difficult on these to throw in a fresh set of valve stem seals. 15 bucks or so for the parts and you don't have to remove the heads. Check YT for some useful vids.How much oil do you burn in 1000 Miles of Driving?
Valve guides are about $7 a piece, and I can see hoe the wear out. I'm sure the OP has considered replacing them, and decided against it.If it's excessive, it's not too difficult on these to throw in a fresh set of valve stem seals. 15 bucks or so for the parts and you don't have to remove the heads. Check YT for some useful vids.
BITOCD guyThis is BITOG, that's what we do, LOL.![]()
The OP did have his Valve Stem Seals replaced!If it's excessive, it's not too difficult on these to throw in a fresh set of valve stem seals. 15 bucks or so for the parts and you don't have to remove the heads. Check YT for some useful vids.
Yes and the mechanic told him the guides were worn. Seals wear faster with loose valves. But you have to pull the heads to do a guide job where you can do the seals with the heads on. If he's not burning too much oil, I'd just run it and observe the old "check oil each gas fillup" maxim.The OP did have his Valve Stem Seals replaced!
Amazing that an Engine with 86K on it would have the Valve Guides worn
Great Discussion, so glad that I went from:Not that long ago 100,000 miles was considered "useful life" for a passenger car and the odometers were 5 digits plus tenths. Also you get into production variation in the carbon content/hardness of the cast iron material. Foundry processes have come a long way.
My 67 Chevy 250 six had 14 thousands cylinder bore wear at 40,000 miles.
what are the zinc and phosphorus numbers on that stuff?Would this be to expensive?
$22.97 per 5 quart jug. It used to be $18.97, but inflation happened. It uses GTL base stock, so it's actually really high quality oil.
Virgin sample? Around 1000 P/1100 Zn. VOAs show it lower, then again, most of them aren't very accurate. However, that's the spec for the Infineum add-pack used by Shell for this lubricant at the recommended treat rate to meet the approvals and specs. The majority base stock is GTL, no Group III or III+ is used in this oil.what are the zinc and phosphorus numbers on that stuff?
I bought it in 2001. 67 convertible, 250 six with Powerglide. It had been sitting for over 20 years but had only accumulated 37000 total miles. Ran great but had a lot of piston slap noise (given the serious bore wear, that was no surprise after I took the engine apart LOL). I did a complete restoration after I retired in 2009, took me three years.Great Discussion, so glad that I went from:
1) Valvoline
2) Castrol GTX
3) Mobil 1
4) Pennzoil Platinum
The 67 Chevy that you had, can you give us a story on this vehicle, because there is more to life than Motor Oil, except here on Bitog?
If I can find it, I would definitely run that. I will look for it!Would this be to expensive?
