Months ago I did a drain and pour with Prestone Steering Fluid plus Stop Leak. The level is where it should be for at least a month and have not had to add any. The reason I used "Stop Leak" was that my steering wheel was leaking on the bottom left of the steering wheel.
It was not a drip but just enough to get it on to my fingers and used a paper towel to wipe it off. Since then it no longer leaks and now it makes a noise while I turn the wheel. So if the fluid level is good what would it be?
