Maybe the filter makers will start putting coupons in the Sunday paper?
You're loosing credibility quite quickly my friend. Just above you stated that the media ripped, not that the media and glue separated from the baseplate. Which is it?quote:
Originally posted by slalom44:
And I had two filters that failed in exactly that location! Fortunately you are not in the business of designing filters.quote:
Originally posted by 427Z06:
I've tried numerous times to pull the endcap away from the media, and it's quite obvious that this is actually the strongest part of the construction.
The clicker bypass is not the old design, that is an interim design. The old design are the ones with a coil spring incorporated into the valve on either end of the filter. It looks like Champion Labs was already was searching for a way to lower manufacturing cost. And as you discovered, their first solution was less than satisfactory. For the record, I won't use clicker bypass valved filters either. You discovered the hard way something people were concerned about the first time they saw that clicker bypass valve. Looks like our concern was justified.quote:
A year ago I had two oil filter failures back-to-back on ST-3614 filters I used on a Toyota. These were the old design with metal endcaps. My car went from burning no oil to being an oil burner during the time I used these oil filters. I cut open these filters and found both of them had failed.
The first one had a rip in a pleat next to the baseplate. The second one had the pleats torn at the glue to the baseplates on both sides, collapsing the pleats. The center tubes were unaffected. I attributed the failures to the clicker-type bypass valves which apparently didn't open during cold starts.
As you asked about if Champion will or won't pay slalom44...I have no impact on that. I don't work there any more.quote:
Further, metal endcaps aren't necessarily the issue, poor design, materials, manufacturing processes, or quality control is. Look at that MANN filter above. I'd have no trouble using that filter as long as it's well constructed and the materials chosen are rugged enough for the environment it's going to operate in.
By the way, Filter Guy, you think Champion Labs are going to pay slalom44 to have his engine repaired, since slalom44 claims the clicker valve filters apparently caused it to burn oil?
Purolator makes some of their filters with cardboard endcaps.quote:
Originally posted by 99:
EXACTLY what I was thinking! There's some "2facism" on this board and you're seeing it right now. Where are all the Fram bashers now? People jump all over Fram for their cardboard end caps. How come nobody's jumping all over the felt end caps and the plastic tube on the STs? The Frams are built like tanks compared to these seemingly POS ST filters. I've never used a ST or Fram filter in my life, so they can both go bankrupt for all I care.quote:
Originally posted by jsharp:
I'm not impressed with the felt endcaps or the assembly quality. Somehow, I think if this were a Fram design people would be trashing it.
I'll stick to Motorcraft, Purolator and Wix myself...![]()
Purolator and Motorcraft for life.![]()
I've seen photos of the cardboard endcaps, but I've yet to see one IRL. I only use two models of filters though. The FL1A/L30001 full size Ford type filter and the FL839/L24457 part that fits the Nissan 3.0L V6. Neither use cardboard...quote:
I'll email them and see what they have to say.
I really don't know how much can be attributed to the failed filters and I find it hard to believe that these two failures could cause this much damage. I know that I was consuming around 1 quart in 3000 miles before, and about three times that afterwards and ever since. A few months after removing the second oil filter I replaced the timing belt and therefore had to remove the head cover(with 205,000 miles). I found the engine was spotless.quote:
Originally posted by dickwells:
I am wondering just what the "damage" was that caused an engine to become an oil burner inside of two filter changes, Bobs preliminary testing seemed to indicate that no filter at all works pretty well if the oil is changed on responsible intervals.
Have them throw in round-trip plane tickets and you have a deal. I'll won't even charge them my usual consulting fees.quote:
Originally posted by Filter guy:
As you're on a one man mission for all things bad about the E-core design, should you ever find yourself in South Eastern Illinois i'll set up a plant tour and engineering tour and you can discuss how media hasn't improved since the 60's, clicker valves, "felt" endcaps, poor design, quality control, and whatever else put's fuel in the tank. They'd be happy to answer. Send me a pm and I'll set it up.
Rather than worry about a bunch of speculation here, cut it open when you take it off, take an objective look at it, and let us what you find. The Ecore is easy to recognize, look for a black plastic cage instead of the old perforated metal in the center. Should be able to tell from the box too if you retrieve it from the trash.quote:
Originally posted by MikeR:
When I changed my oil this weekend, the new ST3600 was a remarkably different filter than the old ST3600 I took off the truck. The filter was physically smaller, the steel used in the canister seemed thinner, and the filter was MUCH lighter.
Is this the new ECORE design? It'll be my last ST filter unless results on this board lead me otherwise. To be fair, it does feel like a $2 filter now.
m
