Actually, re HPL, there is ample substantiating information available, should the consumer wish to access it.
What? As someone who has previously owned a fleet of vehicles, and with a family business that still owns a fleet consisting of trucks, forklifts, and cranes, I’m absolutely concerned with getting the most life out of my equipment as possible. I did not have a set “replacement cycle”, and I’d wager that this is the case for most every fleet of working vehicles that aren’t rentals or customer-facing in some way. Replacing vehicles that don’t require it is wasteful. Using a higher quality oil means I can change my oil less often, which reduces equipment down time.I think the big problem for most end users is they only have one or a few personal examples at a time to worry about or draw any conclusions from... so whatever opinion a person has about the subject isn't based on much but a very small list of personal examples.. I'm 63 years old and at last count I believe I have owned about 25 or so personal vehicles in 46 or so years of driving..which is not a very broad cross section to form a research based opinion on. Now if you could get your numbers from something like a police car fleet or a truck or bus fleet you might be able to prove something, or maybe not.. its also worth saying fleets aren't looking for ultimate life out of a vehicle as they usually have a replacement cycle, so they are looking for good enough while keeping costs down.. its also worth saying very few people keep their own vehicle long enough to get the same thing..
So, to this point, who is aggregating and analyzing this data on "industry standard products". Do you think it's Warren or Walmart tracking this information on Supertech? Maybe it's Costco on Kirkland. Or maybe GM keeps track of who changes their oil at Jiffy Lube or some other quick lube, maybe one that's using a bulk Dexos lube blended with re-refined base oils?Also, while I'm sure HPL has plenty of data in a fleet, it isn't even comparable to the users across the entire industry that standard products have going for them.
The manufacturers have an oil partner. For GM, that's Mobil, for FCA, that's Pennzoil, for Porsche, that's also Mobil, for BMW, it's Castrol. They work with these partners to test different lubricants for performance and for developing testing protocols. Once these protocols are developed, which range WILDLY in terms of deviation from the basic API or ACEA specifications/sequences, the additive manufactures like Infinium, Afton, Lubrizol...etc develop additive packages that pass those sequences. No actual fleet testing is performed on those products.Engineers at vehicle manufacturers are designing in conjunction with standardized products.
Unintended consequences happen regardless of whether the product is approved or not. See Toyota's oil return holes plugging and sludge issues, the Honda VCM fiasco, the EcoDiesel failures...etc. All of these were developed and TESTED with what was deemed an acceptable, approved, lubricant. The testing performed was clearly inadequate.When you deviate from that standardized product, you take on additional risk, even with "improved" performance. Unintended consequences are by definition..... unintended and not easily anticipated. That is the value of standards and best practice methods in general, not just in motor oil use.
For a vehicle within warranty, I tend to prefer a premium approved lubricant just for the simplicity of warranty compliance in the event there is an issue. Once out of warranty, that can be cast to the wind.None of that is stopping me from using it but if I were responsible for other people's vehicles, I wouldn't.
This is my position too. I think what HPL does is cool, but I guess I don't understand "why". If you were to buy a brand new car and run only Mobil 1 in it for 15 years, or run only HPL in it for 15, well, either way you're getting to 15 years on those oils with no issue. Why pay more for the same end result?There is a market for everything. The folks at HPL found a niche. Bravo. Me? In my 50 years of driving, I've yet to have an oil related issue using what's available off the shelf.
But it's not necessarily the same end result.This is my position too. I think what HPL does is cool, but I guess I don't understand "why". If you were to buy a brand new car and run only Mobil 1 in it for 15 years, or run only HPL in it for 15, well, either way you're getting to 15 years on those oils with no issue. Why pay more for the same end result?
In principle, your thought process is valid. I don't think anyone will disagree that the data collected by additive suppliers and OEM's will be broader than what any boutique blender has the resources of doing. To an informed consumer, it should be obvious that the testing limitations faced by a boutique blender will always carry some level of risk and they should keep this in mind when choosing a product for their circumstances. For instance, if the consumer has an engine that has a known history of LSPI issues and they are not confident in the boutique blender's validation of LSPI mitigation, then it may be wise to use an approved lubricant.What is deviated, is virtually the entire product. The base oils are exceptional, and the additive package is robust. That is why we buy it.
Also, while I'm sure HPL has plenty of data in a fleet, it isn't even comparable to the users across the entire industry that standard products have going for them. Engineers at vehicle manufacturers are designing in conjunction with standardized products. When you deviate from that standardized product, you take on additional risk, even with "improved" performance. Unintended consequences are by definition..... unintended and not easily anticipated. That is the value of standards and best practice methods in general, not just in motor oil use.
None of that is stopping me from using it but if I were responsible for other people's vehicles, I wouldn't. I'd use an off-the-shelf product that met the OEM guidelines and I'd change it on a conservative schedule. In my own vehicles, I recognize that ownership for me involves my enjoyment of playing around with maintenance, and my choice of lubricants. It is an odd hobby to be sure, but at least I'm not spending my free time in a nudist colony (no judgment!) or experimenting with mushrooms. LOL....
I'd assume it would pass, it starts with an approved additive package and adds some top treatment (mostly FM stuff like moly) and higher quality base oils.What actually would be the result of taking say....HPL's Euro 5W40 oil and running it through all the tests for VW502, Porsche A40, BMW LL-01, Mercedes 229.5...the same suite of approval most of the popular Euro xW40s possess? Would it pass? If not, what would fail? I have no idea so I'm asking the question to the oil-gods here.
I am inclined to agree, though I'm curious where HPL would end up from an SA standpoint - 229.5 caps it at 1.5%.I'd assume it would pass, it starts with an approved additive package and adds some top treatment (mostly FM stuff like moly) and higher quality base oils.
Yeah, anything with a GPF/DPF specs mid to low SAPS, and since that's basically everything going forward, the full SAPS stuff is going to become less and less relevant.I am inclined to agree, though I'm curious where HPL would end up from an SA standpoint - 229.5 caps it at 1.5%.
The full SAPS specs are kind of an obsolete spec anyway and I expect market share to shrink over time. All of the newer Euro cars call for (or allow) mid and low-SAPS oils now.
Shell claims that too(active cleansing technology)But it's not necessarily the same end result.
See this thread:
https://bobistheoilguy.com/forums/threads/07-odyssey-valve-cover-photos-and-cam-scoring.335965/
That's a 14 year old vehicle, it has:
- Scored camshaft
- Heavy varnish
- High oil consumption
Now, assume you could avoid most, if not all of that by using a better oil.
Even within the premium tiers, M1 API oils don't perform the same as their Euro ones, there's a reason M1 0W-40 is one of, if not the only one they've ever claimed can actually clean.
There are a variety of factors that play into the condition of an engine in 15 years and design is one of them. Some engines are significantly harder on oil than others, which is why Trav was recommending M1 0W-40 for the above engine there, based on his experience tearing them down and them having stuck oil control rings and massive amounts of varnish, even when run on a quality synthetic.
ice engine oils will almost be obsolete over time,I am inclined to agree, though I'm curious where HPL would end up from an SA standpoint - 229.5 caps it at 1.5%.
Can you show me on that page where it claims to clean up existing deposits? There's a difference (a significant one) between keeping things clean and cleaning up garbage from previous lubricants.Shell claims that too(active cleansing technology)
https://www.shell.com/motorist/oils-lubricants/helix-for-cars/pureplus.html
The Active Cleansing Technology is really the heart and soul of the lubricant. It does the wear protection…”
“It keeps deposits off of moving parts…”
“…and it enhances the fuel economy of the lubricant.”
“But it can’t do that alone.”
“It has to do that in companionship with the base stock. And that’s really the amazing part of the new Helix Ultra – is bringing PurePlus Technology together…”
“…with Active Cleansing Technology…”
*snip*
“And for people who have slightly older vehicles, it’s a chance to take even better care of their vehicle and make that engine last even longer by reducing the amount of deposits…”
“…that form in the engine, minimising wear…”
It is possible that having chemistry that cleans up existing deposits is a serious liability for mass-market oils. Customers are notorious for stretching advertised intervals and if an OTC oil has powerful cleaning capabilities, it could result in clogged oil filters and engine damage.Shell is describing keeping things clean, not cleaning up existing deposits.
And that could be why we have only ever really seen that advertised for M1 0W-40? The very heavily fortified full SAPS additive package (lots of detergents) likely means better capability for keeping anything cleaned-up in suspension than something low SAPS.It is possible that having chemistry that cleans up existing deposits is a serious liability for mass-market oils. Customers are notorious for stretching advertised intervals and if an OTC oil has powerful cleaning capabilities, it could result in clogged oil filters and engine damage.
Do you think bean counters know what any of the language in these standards mean? It’s of course drafted by engineers. The only “bean counters” involved would be the engineers or other stakeholders at the oil companies that want the oil to be as cheap as possible to produce. I’m not saying it’s a perfect specification, but I am sure it represents what GM thinks is actually necessary with a small margin built in.Do you know if the dexos standard was created by oil experts & engineers or by beam counters and interns?
Mobil, in comparison, has quite bluntly claimed that the 0W-40 will actively remove sludge and varnish from previous oils.
There seems to be a puritanical obsession with cleanliness here. I have watched a lot of engine teardown video, esp BMWs, and can say that it does not appear that the amount of varnish correlates with wear on things like bearings until it was extreme and obvious that the OCI was not followed. I don’t see a reason anyone here changing their oil every 5000 miles with a quality synthetic should be concerned.It is possible that having chemistry that cleans up existing deposits is a serious liability for mass-market oils. Customers are notorious for stretching advertised intervals and if an OTC oil has powerful cleaning capabilities, it could result in clogged oil filters and engine damage.
Would Mobil 1 0W-40 keep things cleaner than Mobil 1 ESP 0W-30?And that could be why we have only ever really seen that advertised for M1 0W-40? The very heavily fortified full SAPS additive package (lots of detergents) likely means better capability for keeping anything cleaned-up in suspension than something low SAPS.
