HPL NoVII 5w-30, will my ‘18 4Runner like it?
Phila, PA
Getting ready for the 4th July HPL sale…
Currently running Amsoil 0w30 sig.series in the 1GR-FE in the T4R.
Looking to make the move to HPL and favoring the NoVII 5w30 from the specs. especially the HTHS of 3.399.
2nd choice would be maybe the HPL Premium Plus PCMO in 5w30. I am not seeking a Euro oil formulation.
I do 2 year oil change intervals. My usage will be increasing to about 6000 miles over 2 years.
I know I can use any off the shelf oil and the engine will outlive me, but seeking, quiet and smooth, minimal leaks and minimal wear as the engine ages.
Will my engine favor this oil? I know it will do well in the heat, but will it like temps down to 5 degrees F.
Some of this decision is to support HPL, as I believe in their efforts to build the best product and their support to bitog members.
HPL is also going in the driveline as needed.
You might not be “seeking” the Euro formulation, but as it’s a more robust oil and has a higher HT/HS and you pointed that out directly, what are your reasons to order the PCMO over the Euro version in this case?
Just seems odd to me to run an Euro oil in a car spec'd for a API oil and I may end up running this in other vehicles as well that call for a Dexos1gen3 oil.
Also, was looking at HPL SuperCar 0w-30, but is SL rated. Not looking at shortening the life of the catalytic convertors.
If the car is not burning copious (read: quarts plus) amounts of oil, the converter will suffer zero harm from running a Euro add pack.
I’ve used the 5w30 no VII in my Camry 2.5 and 8750/7k generator. It held up well in both situations, but the generator was likely much harder on the oil than the Camry. Viscosity was 9.4 @100c after 73 continuous hours, TBN was 10.8, and fuel dilution was 1.5% at time of sampling.
The PCMO uses a good shear stable VM so I'd probably opt for the PCMO 5w30.
I've run every make and brand in my old 4Runner and settled on Mobil 1 Euro 0w40. It's so good I'm moving everything to it. Use API oil if you want mediocre. Use ACEA if you want the best for a comparable price.
