"So what would you recommend as a good all-around winter tire? I can't predict exactly what type of road conditions I will see, but in MI they will issue you a ticket if you get into an accident."
I'd look at some Nokians. I tried to get some for the truck last year but no one had the tire that was advertised as being available (Hakka LT, studded). The various Blizzaks usually get good marks for traction but with the traction compound typically being pretty soft and only half or so of the tread depth, some people only get one season out of them. As mentioned above the Michelin Alpins don't have big enough lugs for deeper and/or slushy snow. If you look at what people use for 'rubber only' ice racing it's usually Blizzaks or Nokians. Get studs if they're allowed, as they do make a difference on ice. With a RWD vehicle experiment with weight in the trunk, places like Home Depot have 'sand tubes' for such use, get some decent chains for backup, Laclede 'Alpine ?' or something (square material for links, diamond pattern), and take it easy.
