I recently had to replace two snapped wheel studs on my Cruze, one on the driver's side front wheel, one on the passenger side rear wheel. I was rotating the tires, and the snapped studs occurred when torquing the lug nuts down to the recommended 100 ft/lbs of torque with my torque wrench. Prior to snapping them, I had hand-started all the lugs, gunned them down with my cordless impact, and gone around the car to tighten the lugs to 80 ft/lbs. I was using a deep-well socket and a 4" extension, and tightening slowly until I heard the wrench click. The wrench is a 1.5 year old Craftsman 1/2" clicker torque wrench. The snapped ones never clicked, they simply twisted right off. The other studs on the affected wheels felt sort of "stretchy" as they were being tightened, but they did click at 100 ft/lbs.
In the name of safety I replaced all the studs on the affected wheels since it was $20 for 10 studs, the car was up on stands, and the front was a nightmare I didn't want to repeat. The new studs didn't have that same "stretchy" feel the old ones did. I left the torque at 95 ft/lbs to err on the side of not snapping a stud I'd just replaced.
I've tried to recollect the events as best I could. So, was it my technique at fault?
