My wheel stud saga ended with the shop replacing two broken studs along with the wheel bearing on the front driver side.
Prior to this (probably last couple of thousands miles), I’ve started noticing humming noise between 30-40 mph (mostly noticeable on the smooth pavement). Now that the left side bearing is replaced, and tires are rotated (normal wear all around).
I lifted the car and spun the wheels. It sounds like the passenger side is louder, but I’m not sure. , I still hear the noise. No apparent play vertically/horizontally. Can yall have a listen and let me know what you think?
What else can cause the noise?
New bearing
Suspect bearing
New bearing
Suspect bearing
