Originally Posted By: martinq
If the RP can't meet the SN spec it's for a reason. One reason oils don't meet SN is due to cat-con damage.
As Overkill points out, it's really not that simple. A boatload of ZDDP doesn't make an oil great, and certainly isn't ideal for every application. On the other hand, using SJ or earlier levels of ZDDP in an SN vehicle isn't going to cause your catalytic converter to explode. Cats predated SM/GF-4 and SN/GF-5 by a substantial margin, and we didn't see them failing left and right. I don't think harsh oil burners are easy on cats, regardless of how low the phosphorus content is.
The oil companies and automakers have to walk some fine lines. Engine durability and emissions system durability are both important for warranty. If a quart per 1000 miles of oil consumption is acceptable to most North American automakers, I'm sure they don't want an engine and a cat grenading at the same time. Of course, the oil companies don't want to pull out all the stops in blending, ingredients, and R&D and have to soak us $20 per quart, either.
For the record, RP does have SN/GF-5 oils now. Even when they were still SL/GF-3, the oils did not have ridiculously high amounts of ZDDP in them, either. Their SL oils basically "stumbled across" the limits, rather than pole vaulted over them. Their Synerlec additive, however, was a bit of a different story, and wasn't in the RP 0w-40 before either, due to the ACEA specifications it claimed.
