Definitely getting better with each change, anything that filter catches is less floating around in the engine. If you can find it I'd run Chevron Delo xle 10w30 which is a synthetic blend that is a dual rated oil for diesel/gasoline engines, if you can't find that they also have Delo in 5w40 & 15w40 versions. I believe that Chevron is actually one of the best kept secrets, it's such a good oil and for a great price.
You could even try adding a quart of MMO and run that for a few hundred miles as well now that you've gotten most of the junk out of there.
