If I want to use HPL product that’s my business. I don’t want to argue. Everyone likes what they like. End of discusssion. The OP is free to use what oil he wants.
I never said I was arguing. Chill out already. I take serious offense to your first remark. I DO NOT DOUBT HPL products. Sad that you do. To each their own. Everyone has a opinion. I could care less personally
I never said I doubt them. Actually, it’s quite the opposite. I’m setting an account up with them because they offer something I need as a distributor. So I’m literally putting my money where my mouth is. And I don’t particularly buy small volumes either.
HPL and I see eye to eye on a number of aspects.
Just, for cleaning and filtration purposes, there’s a reason why cleaners exists. You can only do so much with a Lubrication oil. If they designed a way to put that much cleaner in their oil, great. I don’t know their formulas so it would be wrong of me to speculate publicly. Just the same reason I don’t get into the debate of brand X over brand Y.
I understand. But when members tell me and show me that their oils do clean well….
I don’t know; maybe I’m stupid and listened to folks that told me wrong; dunno.
I have some HPL 5w20 on way so I’ll report back.
Still cleaning good I see. What oil filter was re installed? Thank You and keep up good workSo now the truck has 131,500 miles on it, son has put about 11,500 miles. The other day he recorded 21 mpg.
The pictures show Mobil 1 Extended Performance 5w30 with 2,300 miles on the Motorcraft filter. Filter got stuck on the block, so it got a bit mangled.
Oil was not changed as a new filter was installed to run the oil to a 5k interval.
This is the pan the filter contents were poured into.
Next is the inside of the filter can.
And finally, the filter media after draining overnight.
The last sub $4 FL-1A we got from Walmart, they are $10 now.Still cleaning good I see. What oil filter was re installed? Thank You and keep up good work![]()
I would say yeah but big diameter as a FL-1A maybe it can hold more stuff/junk. I’m probably wrong.As much carbon as that's still catching maybe an Fl299 or equivalent would be a good idea if it fits.
I wouldn't try any experiments with that engine, it's sludged up and the best thing would be to just let it clean itself slowly but surely, no seafoam, no flush additives, just keep changing the oil and the filter.That’s still pretty nasty! I would change the oil every 3000 miles. Just before toss a can of sea foam in.
I would run a couple idle flushes with a low cost oil. Looks to be cleaning up nicely. Win!So here is another chapter with a correction as the last Motorcraft filter change was at 132,500 miles.
This oil/filter change is at 135k with about 2500 miles on the filter and 5000 on the Mobil 1 5w30.
Castrol 5w30 Edge was added with a Fram XG filter. The Edge jugs cost us a little over $2.
It is still my sons daily and averages 17 mpg and has done a far bit of hauling most likely up to 4000 pounds, was a bit scary to drive over 45 mph on that load... All AC components replaced, and this thing blows cold. I few more non-cosmetic items, like the steering box and a cracked exhaust manifold, need to be addressed but this thing rides nice and is reliable.
Surprisingly it looks like the high amount of junk is slowing quite a bit now. Pictures make it look worse than things truly are this round. Filter media is much better and drain pans have way less debris. Plan is to do a 5k run with this oil and filter combo.
Comments and questions are welcome!
This. Then toss a quart of HPL Engine Cleaner in it to do some gentle cleaning and see what the filters look like going forward.I would run a couple idle flushes with a low cost oil. Looks to be cleaning up nicely. Win!
Very good sir. So what filter went back on? You left the Mobil 1 5w30 in?So here is another chapter with a correction as the last Motorcraft filter change was at 132,500 miles.
Mobil 1 was dumped and Castrol 5w30 Edge was added with a Fram XG filter.Very good sir. So what filter went back on? You left the Mobil 1 5w30 in?
Thank You
