Sludgy 1990 F150 5.0
So now the truck has 131,500 miles on it, son has put about 11,500 miles. The other day he recorded 21 mpg.
The pictures show Mobil 1 Extended Performance 5w30 with 2,300 miles on the Motorcraft filter. Filter got stuck on the block, so it got a bit mangled.
Oil was not changed as a new filter was installed to run the oil to a 5k interval.
This is the pan the filter contents were poured into.
Next is the inside of the filter can.
And finally, the filter media after draining overnight.
IMO there's some really good cleaning going on there. I'd stick with what you've been doing with the XOM product you used.
She's a beaut Clark!
You got this down to a science. After 3 years you still have folks arguing about 'this does this and it therefore it can't do thus'
3 years........
3 years with pictures.....
Disclaimer - I would never have guessed that mere short interval's would have knocked that much gunk loose.
So, the truck is at about 15,000 miles since we got the beast. Some noise prompted a timing chain replacement.
Here are the pictures. Chain was well past done and had a ton of slack.
Usually the chain oil comes from a bleed off passage from the front cam bearing (pressurized). Drip oil from the head could be a possibility. Looks like yours might be the case. Oil runs onto the distributor gear, gets flung forward by the distributor gear, then the oil slinger on the front of the cam gear does the rest.
Yup, should be a grove in the back of the cam retainer that’s also what the slot in the back of the timing gear is.
I think the “slinger” is actually a cam sensor pick up. In the old days it would have been a fuel pump eccentric.
No cam sensor on the EEC-IV Windsor, that's a just a slinger as noted. The hall-effect sensor in the distributor is used for injection and ignition timing.
Wow that's ugly! Can't believe how rusty the timing set is, that's a first for me with a Windsor, and I've had a lot of them apart. Agree with @ka9mnx that it's clearly not getting oil, hopefully the clean-up remedies that, or you'll be doing the set again.
Can you possibly place an arrow on our picture that shows where the oil should be coming from?
It should be coming off the cam and distributor drive gear, IIRC.
Here's the valley, you can see the drain holes all down the middle of it, not much, if anything, is going to be coming out that hole between the valley and the timing area:
EDIT: you can see the hole into the timing area on this one:
You MIGHT get a bit off run-off coming out the top of #1 lifter, on its way to the valley, but the amount would be minuscule.
Now I see the passage. Left side of photograph 5 & 6 (small hole).
Yes, there's the hole right in front of the cam that feeds behind the upper gear, lubes that area and then flows through those two channels, and there's also the spray coming off the timing gear itself, IIRC.
