My personal experience with MotorKote
Texas
I highly recommend this product. I don't have any affiliation and I've read the whole chlorine thoughts which MC denies is part of their product. Seems the only thing referenced is an Amsoil document that I believe has even been deleted.
Anyway I wanted to give it a try after watching the project farm video. Why not, it's fun. I have a 2024 Ineos Grenadier and a 2014 Chevy 2500HD gasser. I do my oil changes every 5k using the FCP Euro setup and I bounce around trying different oils. I do used oil analysis on everything and bought CAT kits in bulk on ebay for $5-$7 each. I like data. I fly for a living, I manage two private jets, it's just part of my routine to want to do these things and know more. I'm 100% aware I could just turn the brain off and buy walmart oil at my OCI and be fine, but I can't.
I baby my Grenadier, kind of. I don't buy something to not use it. I've beat it down in Moab, used it on the ranches in 105+ Texas heat, and a little while ago I took it to an offroad park as a shakedown test before going to a large Grenadier meeting in Moab. During that test we straddled a log that was hidden in a sandy bottom. The wheels buried and the vehicle couldn't sink down for traction due to having this tree trunk under us. It was raining a lot and in some places went as much as 12". The creek we were crossing started to fill more and after a couple hours of rapidly rising waters things finally settled down with water up to the hood. The engine and air intake was under water.
After pulling it out with a backhoe I trailered it home. I pulled the drain the transmission, no water only oil. I pulled the drain plug to the engine and full of water. Clear water. Gallons. I'd shut it down and it sat there with the flowing water pushing against it's air intake causing the water to go down the intake, past the turbo, and into the engine through the open valves. So I drained all the water, pulled and replaced the plugs, did two oil changes, and now the thing is running great again.
I 100% am a firm believer that I still have my engine and vehicle running because of motorkote. There's going to be the negative nannies that enjoy walking through life with blinders on and they'll say "there's no laboratory proof". Well I use real world examples. I noticed a direct increase in MPG after my first tank of gas. I gave some to a buddy to run in his Buick company car and he got the best MPG he's ever seen. I can't remember the exact numbers but went from something like 28mpg to 31mpg. I've put it in my 2500HD 6.0l gas truck with 231k miles now (I bought it at 224k miles) and had my average mpg using the fuelly app, odometer, and gas station readout to the thousandth decimal go from 9.7mpg to 11mpg over the course of about 3k miles. I haven't done mpg comparisons with my Grenadier but I have no doubt it helped save my engine from the water intrusion. I don't have any affiliation with the product but wanted to write my experience so anyone searching the webs might read my firsthand account.
I have not done UOA on the 2500HD since adding the motorkote. I don't know how it responds to high temps, what it's durability is like, etc. I read form many truckers that all experienced great results using it on their haul rigs so I thought I'd try it and from my first hand experience it's the real deal. I know there's a lot of snake oil products out there so was hesitant trying it. There's many products I've used for different reasons with no results but motorkote is legit.
How did the rest of your grenadier fare. How's the interior. Or was it just sharply downward with the front wheels being sunk down and the rears not having enough traction to pull out with only the front end under water saving your interior. If so have you popped your fuse box open.
I admire your courage.
Whatever works...it's your money and vehicles...carry on
How did your engine fare without Motorkote when you flooded it with water, just so there is a control sample against which to base your claim that it was the Motorkote that saved it?
And what does Motorkote claim to do (backed by published science) that a fully-formulated oil does not? I’d love to see it in your words since obviously you’re invested in its efficacy.
Glad your Grenadier survived, that must have been a harrowing experience.
That's the fun of words and exactly why I stated that I BELIEVE it was what saved it and that there will be plenty of people that will never want to hear it or accept it. Watch the project farm video on running an engine with water in it. I don't have pure data but based on everything everyone's told me (including the dealership) that engine should be toast. But having used the product I've found it be worth using. When you used it what were your results?
  • Like
Reactions: Arc
Overall it's fine. It had water through all of it. It's built like a tank. Replacing a wiring harness but compared to my Land Rover and other vehicles it's a stud. I never felt my LR would hold up on washboard dirt roads all day but the IG takes it better than my farm truck does.
What's the courage part about? I guess if people are going to knock it I'd like to know their reasoning and when it's failed them. Have you ever seen any incident where it hasn't performed? Have you ever seen it cause failures? What is your rationale?
You tell me lol
Because there is nothing in it but thin oil, some of that may be chlorinated paraffin. It dilutes the oils ad pack, thins it out, which may explain a bump in fuel mileage. The 100c viscosity is in the 5-6cst range. A voa below shows there is no ad pack so adding a quart of this reduces the existing add pack by 20% or so.
Have you ever seen bearing wear metal tests performed with it? Take a 0w20 and compare it motorkote. There's a lot more to oil. There's no chlorinated paraffin in it.
  • Like
Reactions: Arc
What are chlorine thoughts?
Feel free to absorb my compliment in this anti additive climate
Some people have talked themselves into believing it has chlorinated paraffins which can lead to engine wear or react with moisture. There was a single cummins that failed at some point and amsoil put out a paper it was due to motorkote and chlorinated paraffins. Since there motorkote has stated, and still does, there are not chlorinated paraffins and went after amsoil asking them to show their work to support their statements. Amsoil has since pulled the document so unless there's new evidence out there then there's, to my knowledge, zero failures associated with it. Truckers seem to love the stuff. After using it in multiple vehicles I love the stuff. The same people that knock it saying there's no data will watch a bearing wear metal test and not accept it. Not that it counts for everything but it most certainly counts for something. My personal experiences are what I'm referencing and I've had positive results. Measurable results. I always run fresh oil, I run the same ethanol free 91 oct gas in everything that I buy from the same United Ag, and I've seen measurable changes. It's $30 for me to put it in all three engines, big whoop.
