You said earlier that the pushrods and rockers were removed / cleaned / reinstalled. The rocker fulcrums torqued to a certain torque spec. I understand the valve adjustment requires a certain procedure, more than just torquing down the fulcrums.
There's no valve adjustment on a ped-mount SBF, the rockers just torque down.You said earlier that the pushrods and rockers were removed / cleaned / reinstalled. The rocker fulcrums torqued to a certain torque spec. I understand the valve adjustment requires a certain procedure, more than just torquing down the fulcrums.
I'd be swapping out the filter a few times over the OCI. With that much crud in the filter, it was probably bypassing and allowing crud to get by the filter.I suppose this is now part 2:
So we got the transmission installed.
Truck back on the road but it was putting us on the side of the road more and more often. It finally got to be 1 mile, wait 15 minutes, another mile, more waiting. Turned out to be a bad fuel pump. We had installed new tank/pump, filter and rebuilt the fuel injectors since we were there. So we dropped the tank and installed a Denso (Made in USA!) pump, soldered the wires and has been dead reliable since.
We put in rebated M1 5w-30, a Motorcraft FL1A and ran it to 123,000 miles. 1,268 miles on the oil and filter and here are some pictures.
Magnets doing their thing.
Bottom of the drain pan after draining oil out of the filter with no metal particles, pieces are not solid between fingers. Oil looked pretty good.
Now the fun pictures showing the filter doing its job and collecting. Truck runs very well by the way. (Wifey's pants...)
Another magnet at the end of the can doing its thing.
Next is sludge that was stuck in the filter and poured out of the can; all outside of the filter...
We intended to just remove the filter, open it and judge how far to go with the oil. Seeing this though we dumped the oil, dripping out overnight, and will install another Motorcraft filter.I'd be swapping out the filter a few times over the OCI. With that much crud in the filter, it was probably bypassing and allowing crud to get by the filter.
Looks like the deposits are relatively small and making it through the pickup screen to the filter. Only way to verify the screen is to drop the pan and look, but obviously a pain unless maybe you have a borescope you could get in the drain hole and see the screen.Anyone have concerns with the pickup screen?
They seem well made and are a good fit for this clean up phase I just wish the filter media filtered smaller particles and the ADBV was made of silicone. Seemed to not have the tearing element issue, stamped made in USA with the old school string. Bought these least year, are they still this quality with current production?Keep running those Motorcraft FL1A filters. IMO they are better than most filters on the market.
I’d say keep using the MC FL-1A as they are working.They seem well made and are a good fit for this clean up phase I just wish the filter media filtered smaller particles and the ADBV was made of silicone. Seemed to not have the tearing element issue, stamped made in USA with the old school string. Bought these least year, are they still this quality with current production?
The plan is to finally get to 5K changes or 1 year. I suppose the FL1A is fine for that but was looking at the Fram Ultra also.
They seem to be attracting stuff before it gets into the filter. I was thinking they might be trapping ferrous material that has been inside the engine for some time, only had the truck about 10 months now. I get magnets free and I cannot see how they could cause any harm.Not sure what good the magnets are doing—if the motor is shedding metal then plugged filters from sludge is pretty trivial. Are the magnets getting ferrous material, or is stuff just happening to stick to them?
