Originally Posted By: BrocLuno
I'm convinced it's heat related. Gas engines that run in cold air like tractors plowing in cold frosty conditions (say Cletrac) get sludge under the valve covers. Same engine running hard in summer, no issue. Same with the gas farm trucks. To me, it's a form of condensation on cooler surfaces.
I've had sludge in marine engines that run a 160*F thermostat and direct raw water cooling. Same engine, same oil with heat exchanger running over 180*F, no issues.
I guess Mobil1 was the most impervious to this... But Pennz Ultra has to be a step up with GTL. And now Rotella T6 10W-30 is GLT based, so we'll see ...
Dispersancy of an oil drops with temperatures, so the sludge buildup will definitely start in the cooler areas. Chack out the Ailine point for the different base oils. That's the temperature point where equal amounts of oil and aniline mixed seperate again. There's quite a difference at the temperature this happens between base stocks, with group III and IV being worst; Group I clearly better and Group 5 king by a large margin. Aniline is a higly polar compound, and stays better solubised in high polarity oils. Now according from what I picked up from SonOfJoe, the VII is a majour contributor to the loading of the engine and the following deposits. When those break down they formpolar compounds aswell.
GTL would likely have an aniline point very near to PAO, so while the inherent high VI means less VII needed, the ashless dispersants will still need to be high and those are prone to evaporation. So while you might not have issues in summer, the higher temperatures the oil runs at as a whole probably degrades the oil enough for the issue to arise when it's cooler.
