good questions c3po, in accordance with General Order Six
General Order Six [GO6]
Northern Research Force
1. In view of the common human tendency, when seeking to explain observations, to favor the first speculation that comes to mind, the following procedures will be observed by all ranks:
[a] No speculation by any member of the Services will be reported to higher-ranking personnel unless accompanied by a comparably plausible alternative speculation, or [ii] a detailed procedure for testing the one proferred.
If the said speculation occurs during a general discussion, either formal or informal, then or [ii] may be delayed until after the end of said discussion. Alternative ideas contributed by participants other than the originator of the speculation will be regarded as satisfying 1[a] above.
2. This rule is not intended to discourage speculation, which is recognized as a necessary first step in the development of any body of knowledge, but to help preserve objectivity as far as possible in both private reasoning and public debate.
3. The Commmander of any research unit, whether of observer or theoretician grade, is authorized and advised to use discretion in the detailed enforcement of this regulation.
4. No punishment more serious than reprimand is warranted for violation of this rule.
- Half Life by Hal Clement
