- Joined
- Jul 18, 2021
- Messages
- 291
Just now seeing this thread, sorry for the hold up. Sounds like you want to know what material the bypass valve is made of on the LF16002, correct? I'll see if I can get to the bottom of it.
The anti-drainback valve, yes please, thank you!Just now seeing this thread, sorry for the hold up. Sounds like you want to know what material the bypass valve is made of on the LF16002, correct? I'll see if I can get to the bottom of it.
Found out that we do make this filter in-house, and the anti-drain back valve is made of nitrile (NBR). Hope that helps!The anti-drainback valve, yes please, thank you!
Yes, it does, thank you.Found out that we do make this filter in-house, and the anti-drain back valve is made of nitrile (NBR). Hope that helps!
You should post a pic of it up, because afaik you have come upon a unicorn "Fram" OF. Only blue-ish adbv I'm aware of, Mitsubishi OEM and Super Tech MP series.First time seeing this on a FRAM but got a fram orange can for neighbor's Honda today. Has a blue ADBV.
Here is the unicorn. View attachment 81730View attachment 81731
no one says silicone has to be orange...silicone can be black...blue...red and clear and maybe more colors...This thread by @The Critic from last year:
https://bobistheoilguy.com/forums/threads/black-silicone-adbv.324860/
Had me thinking about commercial filters that are high-end that you'd THINK would have silicone ADBV's, but they are clearly black. How would one tell if the media from the company doesn't state one way or the other? @ZeeOSix mentioned freezing it, but that's difficult to do without sacrificing a filter.
In particular, my query resides in relation to the Fleetguard LF16002 which is the cross for the PH2/XG2 and FL-820S filters, using Fleetguard's synthetic nanofibre (I presume NanoNet) media. I've run the FL1A version on our boats and plan to continue doing so.
I recall them being a Parker unit, but I think they are almost all Parker, regardless of being nitrile or silicone.
I wonder if @NashNative our local Fleetguard guru would know?
The point is that they usually are, hence the purpose of this thread, to seek out exceptions.no one says silicone has to be orange...silicone can be black...blue...red and clear and maybe more colors...
You going to freeze one for us? LOLThe black Fram ADBVs have a “satin” appearance, almost like silicone tubing. Nitrile has more of a “dull” look, IIRC.
Ford Racing filters have blue “flappers“Here is the unicorn. View attachment 81730View attachment 81731
