Don't I have a Pentastar with 150k that still runs like new.So I’ve got a 2015 pentastar with 104k and it’s had 5w20 it’s whole life - mostly Mobil 1 with some Castrol and Valvoline OCI’s. I’ll be sure to tear it down at 150k.![]()
Ha! Child's play, one of our sister companies ran a small fleet of modular engine Ford delivery vans to 900K miles on M1. They'd scrap 'em when the engine failed, generally a head gasket leaking coolant externally, followed by overheating.Don't I have a Pentastar with 150k that still runs like new.![]()
i think one of these "studies" they "formulated" their own 0W-20 because none were generally available and the only 20W oils then existed as racing oils, which, they either couldn't afford, or were afraid they might thwart their experimenter confirmation bias....
There were plenty of off the shelf x20 oil in 2010 but I think you are right about their own blend for, both, the x20 and x30 oils tested. But in no way did they bias one oil over the other.i think one of these "studies" they "formulated" their own 0W-20 because none were generally available and the only 20W oils then existed as racing oils, which, they either couldn't afford, or were afraid they might thwart their experimenter confirmation bias....
Who said the study was done in 2010? I'd be surprised if anyone posted any study newer than 2000. It was probably posted HERE in 2010....There were plenty of off the shelf x20 oil in 2010 but I think you are right about their own blend for, both, the x20 and x30 oils tested. But in no way did they bias one oil over the other.
No, in the original post he mention 2010 which is, I believe, the paper I have with (approx) that era.Who said the study was done in 2010? I'd be surprised if anyone posted any study newer than 2000. It was probably posted HERE in 2010....
I do have other papers on the subject that are much older than 2010, though.
I don't remember that one but I believe you.Before the switch to 20 wt oil there was a paper (pretty sure by SAE) that described shorter engine life of 20 wt as compared to 30 wt oil.
As I call the requirement was that the engine would last 200K miles. I recall that number got reduced to 150K miles. Wish I could resurect that information. It was around 2010.
Agree, Al, after your edit. Just pointing out that some engines go to much greater lengths to carefully control the oil temps, and not necessarily at 100C. That was all I meant.Its assumed at 100C (engine operating temp). 20 wt. =8 cSt. 30 wt = 10cSt
This is what has convinced me to step up to 5W-30 from 20 weights too. If 20 weights are equal for protection, then why do non-CAFE countries get owners manuals that call for thicker oil for the same temps where US owners manuals call for exclusively 20 weights?If you look at the manuals for new cars in places like Australia, they will show a range of oil weights that are compatible based on temperature with the same engine that here they will spec purely at 0W-16/20. So if the oil weight has to do with new bearing width or other design changes, how is this possible?
Exactly. Unless you are measuring your bearings before and after their service life, then UOA does not indicate total engine health. People lean on UOAs for way too much.As always, UOA results do not provide engine wear information.
Agree, Al, after your edit. Just pointing out that some engines go to much greater lengths to carefully control the oil temps, and not necessarily at 100C. That was all I meant.![]()
Maybe. This is the chart for my Toyota 2.5 in Australia. Basically you can run anything you like.They might not have 0W-16 in Coober Pedy.
Also, in the USA it says you may use 0W-20 if 0W-16 is not available, but you MUST change it back to 0W-16 in 5000 miles - at the next 6 month service interval - rather than the specified 10K interval - or your car will self destruct (well I added the last part, couldn't resist) They give no such warning in Australia.
There are enough thin vs thick arguments on this board that I don't think we need anther, but I think you can infer from this at least that the engine oil viscosity has to due with a lot more than simply lubrication.
I personally don't have an issue running 0w-16 in my engine, but do prefer 0W-20.
I'd drive it carefully home taking care to keep the revs low, then dump the 0w-16 for some 0w-40.
What if it Lives in 115F Temps driving 90mph
