Originally Posted By: ExMachina
Don't make that bet*
*This has been discussed before, Donaldson makes some insanely efficient versions of their synteq media.
Show me a filter media that is better than 80% at 5 microns, with the high dirt loading capacity of a Fram Ultra, and I'll change brands. I'm not brand loyal, only performance loyal. For example, I was a Cleveland Cavaliers fan until they lost the championship to Golden State, just saying....
....And MicroGreen oil filters don't count, they cheat and put in a 2 micron filter in there. Not fair.
I can show you the media but you won't be able to run the filters. Donaldson primarily makes filters for OTR trucks, mining equipment....etc. Their selection of car filters is tiny and the only ones that get the Synteq media are the Ford and GM small blocks IIRC.
I'm not even sure you could rig up a filter head that accepts an ELF to your engine TBH. And the size of the filters would probably be a problem for your oil pump
http://www.donaldson.com/en/engine/support/datalibrary/070617.pdf
Start on page 19.
Synteq - 99% @ 16 microns
Then page 30, which is for Cummins applications, Synteq ELF7900 filter is 99% @ 15 microns.
Most of their newer literature for the Synteq stuff just lists >90% @ 10 microns.
