- Joined
- Sep 28, 2002
- Messages
- 39,799
Quote:
I can only conclude, then, that the high lead came from the bearings, possibly as a result of the high 8.5 TAN to 2.0 TBN ratio. Iron, by the way, was also higher than I would have expected, though not extreme like the lead.
This I would not argue with except that I've never personally seen Pb as a result of corrosive agents. Fe ..for sure.
So, although the Pb surely came from the bearings, I don't think it is due to the high TAN numbers. I could surely be wrong. The reason I say this is that I've run oils out to the higher TAN levels (admittedly where TBN was still decent) and had no Pb reading at all ..but tons of Fe and maybe Cu.
Run the PP out to the same mileage and the same time span and see what it shows. You may get like indications.
Either way.... switch hitting oils makes it very hard to view clearly.
