Castrol GTX Magnatec 5W-30, 8330 km, 2018 F150 3.5 EcoBoost
SK, Canada
just changed oil recently & sent a new analysis away.
Truck has 149444 kilometers, or about 93000 miles on the engine & a little shorter OCI than the last one.
Looks like a pretty good report, but seeing silicon on these last 2 samples have been above the average.
Have noticed some oil seeping on the engine, looks to be coming from above the starter, & 1 intercooler line appears oily on the outside.
Maybe I will have to check/ tighten hose clamps on intercooler line.
Also replaced the air filter at the same time.
Having problems trying to attach a PDF of the analysis report. Will try to figure something out. Not as convenient when I need to manually enter it all.
------------------Castrol Magnatec GTX synthetic 5W-30
km on engine-------------------103850---------------------149444
km on OCI-----Virgin------------10212-----------------------8330
Aluminum-------0-----------------3----------------------------2
Chromium-------0-----------------0----------------------------0
Copper----------0-----------------4----------------------------3
Iron-------------0-----------------12---------------------------9
Tin---------------0-----------------0----------------------------0
Lead-------------0-----------------0----------------------------0
Silicon-----------0----------------17---------------------------18
Molybdenum---72---------------73----------------------------81
Nickel------------0----------------0-----------------------------0
Silver-------------0----------------0-----------------------------0
Potassium--------0----------------2-----------------------------1
Sodium-----------0---------------4-----------------------------4
Boron------------203 ------------54 (Lower Critical)---------79 (Lower Critical)
Barium------------0---------------0-----------------------------0
Calcium---------1303-----------1210-------------------------1260
Magnesium-----709-------------808---------------------------580
Manganese--------0---------------1-----------------------------1
Phosphorous----709-------------678---------------------------796
Zinc--------------938-------------883---------------------------875
Visc 40C---------62.3-------------59.7--------------------------54.4
Visc 100C---------10.6------------10.1----------------------------9.8
Visc Index---------161------------157----------------------------168
Fuel %---------------------------------------Not Flagged----------
OXD-------------------------------18-------------------------------9
NOX-------------------------------30 (Upper Critical)-------------19
COX-------------------------------31 (Upper Critical)--------------20
SO4--------------------------------7---------------------------------9
Attachments​
Missouri
Great reports, I wouldn't change anything. The silicon level looks fine for an 8,300 mile run. I would expect to see less than 10ppm/5,000 miles with a paper filter.
cdlamb
SK, Canada
