In laymen's terms - what are the ingredients of Rislone High Mileage oil treatment and what do they do specifically ? https://rislone.com/wp-content/uploads/2021/06/4102-SDS.pdf .
Is this essentially the same type ester from lubegard biotech also.It has tmp ester % unknown but guess 10-20 % . Other base oil that I do don’t know.
I've been warned about using HM M1 as Drew and a few others on the customer service help desk admit using that oil could swell seals and such but after using it a time or two then it becomes the case of the seals could have unfortunate consequences.Rislone claims to clean rings , quiet lifters and reduce wear ... I suppose the makeup of the liquid has ingredients to perform those tasks ... On the other hand a short 3K mile to 4K mile of M1 High Mileage 5W30 (with increased detergents) may perform nearly the same cleaning tasks ? For average grocery getters - running a synthetic D1 / Gen 3 oil with a clean filter for shorter (
No lubegard biotech tech ester is different than rislone both as far I know both made using different materials. Both products made to used different biotech is protector and rislone is cleaner.Is this essentially the same type ester from lubegard biotech also.
I've been warned about using HM M1 as Drew and a few others on the customer service help desk admit using that oil could swell seals and such but after using it a time or two then it becomes the case of the seals could have unfortunate consequences...
Rightfully so, but it was worded more in the ways of if you keep using it and then stop it could be a problem.Did you ask Drew if he graduated yet? Never "swelled" seals but did condition my fathers Taurus' seals so that it stopped leaking during the OCI...
Hopefully , not much if any seal conditioning going on with Rislone High Mileage Engine Treatment ... I bought to see if lifter tick could be quieted down a bit along with some moderate oil consumption taking place in a vehicle under 50K miles . Now perhaps better just to run a D1 / Gen 3 rated synthetic oil for lower OCI's and call it a day ... Rislone sure does smell good though (lol !)I'm sure there is some overlap, though composition is at least likely somewhat different. The HPL Engine Cleaner uses esters and I asked their rep here if it could positively effect seals by conditioning them as they do not explicitly state this and he unequivocally stated that yes, that was the case. There is definitely overlap even if a product has a differently advertised intent IMHO...
Rislone is now basically a "High Mileage" Engine Treatment, so I may contact their reps regarding this. They list it as a HM-centric engine cleaning product but state nothing about seal conditioning as HM oils do...
With all here that have run HM oils in their cars, it doesn't seem to be an issue at all. Even non-HM oils condition seals otherwise your car would spring leaks......Rightfully so, but it was worded more in the ways of if you keep using it and then stop it could be a problem.
Better result if used in an ester free oil?
Conditioning is a marketing term. You can coat elastomers, clean them or make some of them swell, but if the polymer backbone has oxidized or cross-linked you cannot reverse that.I doubt it. Rislone High Mileage Engine Treatment makes no claims about seal conditioning interestingly...
