I guess like most here with Rhino Ramps, if you really want them, get the 8000lb axle capacity ones, for a much lighter vehicle and store them properly, they will be fine for a long time.
I've learned that lots of plastic doesn't like being stored in my steel roof shed, with some what I thought were well sealed solvents and gas containers, at higher temperatures in the summer. Wood and steel stored in the same shed doesn't degrade at all.
Simplest, toughest, cheapest, and longest lasting is just softwood.
The race ramps are nice and light and plenty strong when new, but they don't actually say what they are made of? I assume polyurethane foam which is fine for most automotive fluids, but might dissolve with acids or solvents used for body work? And they rely on a coating to keep the internal foam protected which depending on your usage, the coating may not last.
Also don't use them on your driveway, or maybe even in your garage on a hot day, 120F is their max temperature for usage, and 150F for storage.
