Originally Posted By: jimbrewer
Originally Posted By: stchman
I still maintain that if the manufacturer recommends 87 octane, going to 93 will net you no benefit.
Maybe, but read that owner's manual carefully. Some of the manufacturers waffle on that quite a bit nowadays. Ford F-150 says to use premium while towing. Says elsewhere that the car "benefits" from higher octane gas. In yet a third place, it says to use 87 octane gas. You know the next line about about how its OK to use lower octane gas in high altitude areas? Ford doesn't put that in there anymore.
I'd go so far as to say that yeah, for marketing reasons they make sure they run on regular. But the cars really want Premium.
GM does not waffle here with the Silverado.
4.3L, 4.8L, 5.3L
Quote:
For all vehicles except those with the 6.2L V8 engine (VIN Code 2),use regular unleaded gasoline with a posted octane rating of 87 or higher. If the octane rating is less
than 87, an audible knocking noise, commonly referred to as spark knock, might be heard when driving. If this occurs, use a gasoline rated at 87 octane or higher as soon as
possible. If heavy knocking is heard when using gasoline rated at 87 octane or higher, the engine needs service.
6.2L
Quote:
If the vehicle has the 6.2L V8 engine (VIN Code 2), use premium unleaded gasoline with a posted octane rating of 91 or higher. You can also use regular unleaded gasoline rated at 87 octane or higher, but the vehicle's acceleration could be slightly reduced, and a
slight audible knocking noise, commonly referred to as spark knock, might be heard. If the octane is less than 87, you might notice a heavy knocking noise when you drive. If this occurs, use a gasoline rated at 87 octane or higher as soon as possible. Otherwise, you could damage the engine. If heavy knocking is heard when using gasoline rated at 87 octane or higher, the engine needs service.
All this sounds to me if you own a Silverado not equipped with a 6.2L engine, use 87 or better octane. If you own a Silverado with a 6.2L engine, you can use 87 octane, but the engine may knock, so you really should use 91 octane or higher.
