It's clear from looking at the viscometrics of the various Redline formulations that they are using a pretty thick basestock blend, with little or no VI modifier. A comparison of 10w-30 synthetics makes this pretty clear:
CCS viscosities @ -25C:
Redline 10w-30 ...6500 Centipoise
Mobil 1, 10w-30 ...3800 Cp
Amsoil 10w-30 ...3100 Cp - new data, not yet posted
Note: Based on these, both the M1 and Amsoil formulations would meet the CCS viscosity of a 5w-xx oil....
If you look at all the Redline formulations, the CCS viscosities are in the 5000-6500 Cp range. In other words, they are just thin enough to meet the SAE J300 test standards for cold cranking. The CCS viscosities for the various SAE grades are about like you'd find with any good group II, petroleum oil. In fairness to Redline, the pour points of their lubes are lower,since the synthetic basestocks don't contain any wax.
The benefit of Redline approach is that you end up with a very shear stable, low volatility oil. The lack of VI modifier also means it will run very clean.
Any formulation approach you take is a compromise to some degree. If you want to optimize cold weather performance, you give up a bit at the high end, and vice versa. Given the nature of Redlines customer base, I think this is a good compromise for them to make. The thicker basestocks are also more expensive, so it's easy to understand why Redline isn't $4.00-$5.00/quart ....
Tooslick
Dixie Synthetics
