MK, I have no doubt that this is the case, but if Redline oils are mostly esters, why aren't their pour points extremely low (like the German Syntec 0w30)?quote:
Originally posted by MolaKule:
Redline uses a majority of PE and Di-PE polyol esters (current jet engine lubes).
That's ok, BOBISTHEOILGUY owns an Escort wagon too, and I've often told him he was crazy for trying to extend the life out of that little car!quote:
But I'll bet many of you are laughing your butts off at the thought of someone with an Escort using Red Line. Go ahead and laugh.
BTW,
I have sent in a sample of Redline 10W30 for analysis and will post it here. My plans are to use Chevron Supreme conventional 10w30 in the next run and attempt to duplicate some of the results from others on the board using the same oil and engine in the Nissan K24DE engine.
I will then compare cost vs. performance and board members can draw then draw their own conclusions. This may take the rest of the summer to complete, so don't expect instant gratification!
I am curious to see the results of this test as I have extreme interest in the cost vs performance part of the equation when lubing our engines .
I did a search but came up empty . Can someone point me in the right direction to see the results ?
I use MT90 gear oil in my 93 MX6 V6, so far no problems at all. That's because it's 75w90 GL4, exactly as recommended by Mazda.quote:
Originally posted by sprintman:
Like the products, not so keen on the price.
I've come across posts on the web in the past, among the camaro/firebird/corvette crowd where owners were stating manual transmission problems either when using or after using Redline MTL. This is on the Tremec 6-speed T-56 transmission, common to all these cars. It is always easy to conclude it was the fluid's fault, but if you look at things objectively, like one corvette owner I remember who lost a transmission. However, he autocrossed the car. So was it really the fluids fault? Or is it more likely the fault of the components in the transmission? And I've seen many others post, in addition, which are questions like how do I check for bent pushrods. Which means they're beating the **** out of the car, so parts that are designed to wear (synchronizers) wear faster and fail-> not do to the fluid but use and abuse and/or the compounding of mechanical problems. No fluid will make a piece of equipment last forever; they will all have their problems no matter which fluid you use as the lubricant.quote:
Originally posted by Leo:
Actually the reports about MTL I heard were from Nissan and Mazda Miata forumsBut I dont trust everything I read, just take it with a grain of salt.![]()
The same thing happened to my Vic. I thought i was going crazy...quote:
-Water Wetter sludging up coolant reservoir bottles. I wonder what the rest of the cooling system would be like.
I have not seen Red Line MTL damage a synchro either. I think people got mixed up with some of the synthetic ATF's in the 2003 SVT Cobra, which was the first use of carbon synchros in the TTC T-56 transmission. The synoil ATF's were too lubricious, and there were reports of "glazing" of the synchro blocking rings.quote:
Originally posted by JohnBrowning:
LEO I belive that you have read all of those things. I question the source of information though. It has been my experinces that shade tree tuners always look for a scape goat to make up for their mechanical failures. I see it all the time in amature import raceing. Their is a lot to be said for self actulization! I have used all of redlines products at one time or another. Their is no way that water wetter if used properly could cause any sludgeing!I ran it year round for 3 years with no sludgeing or corrison. I use MTL in C5 corvettes and have not seen any problems!! I also use it in old corvettes that origanaly shiped with Whale Oil in their Muncie manual transmissions. Their is nothing that would convince me that MTL ate a syncro! I am not aware of any other GL4 compliant fully synthetic lube. Last I checked synchremesh was semisynthetic. No oil blender with their name on the bottle is going to misrate a fluid and open up the floodgates to litagation and class action suites.
Smokey Yunick has also used a Polyol based oil and said similar things. The parts look as though they have never touched. SMokey would not name the brand of oil. The only domestic polyol based oil I am aware of is Redline.
Buster, Buster, Buster,quote:
Originally posted by buster:
Usually when I give my opinion, the opposite ends up being true. So it's most likely a great oil.![]()
