Yes, all changes since the factory fill have been Redline
Do you by any chance still have any of the jugs? I'm curious about the stamped manufacturing code. I wanted to try and decode when it was manufactured.
The additive numbers seem to be a little bit all over the place.
Molybdenum should be around 500 ppm.
ZDDP fluctuates quite a bit between samples.
I am starting to wonder about the consistency of their blending process, quality control, and formulation changes that they keep quiet.
Red Line 5W-40 is supposed to be thicker than other 5W-40 oils, according to their website:
we saw with another BMW engine in another thread
Red Line 5W-X and 10W-X oils aren't supposed to behave like this, even with fuel dilution. At the low miles of each OCI, coupled with the heat that a twin-turbo makes, the Red Line 5W-40 should have been at around ~14 cSt @ 100C in each sample. Something tells me that they ... cheapened their formulation.
As a Red Line customer, this doesn't make me happy because from how things look here, this oil performs about the same as any other Euro 5W-40. Sure, it's good that it does, but not at $60 a gallon.
The Silicon levels look perfectly normal for Red Line.
That was the only sample that displayed extra fuel dilution. I attribute it to it being a very cold winter and very short trips. I was less than 2 miles from work, so I figure that is why it was higher.
All your samples have fuel dilution, some more, some less. The flash point of RL 5W-40 is pretty high when new.
