Red Line D6 and ZF 8 Speed
Brownsburg, Indiana
Red Line claims compatibility with the ZF 8 Speed. Any thoughts?
I know it is apples to oranges, but I have run their C+ fluid in place of ATF+4 in my 2018 Wrangler manual gear box and it smoothed out the shifting a little bit. I have been running it for nearly 80k miles with no issues, so it has given me great confidence in Red Line.
Has anyone run this in a ZF in a Jeep or Ram?
I am coming up on 60k miles on my Gladiator and am going to service the transmission. Warranty will be over at 60k. I´m just thinking about it as I creep up in the next couple months on this swap. I do plan on putting a PPE drain pan on it with a drain plug to make swaps easier in the future. It also happens to add 1 quart of capacity, although that isn´t really what I was after.
Personally I would not take the chance and would use the Mopar fluid and the factory filter, which I think is integrated into the pan as it is on my truck. A second cousin is a CJDR tech and has told me not to mess around when it comes time for mine - just use the Mopar fill% It is also unclear what you would achieve by adding additional capacity as this is a very well designed and built transmission. Seems like risk for little real return.
You might find some useful information here. I used to pay extra for Red Line as well, there is a Pelican Racing store near my house that sells their products. These days I just go to Walmart and get Maxlife.
If they claim compatibility, I think it would be fine. Many many people use Maxlife in the ZF's and I haven't heard of any issues there.
I haven´t found a single Maxlife user with issues and I think it is pretty common on the Ram forums. Not finding as many folks using Red Line, but I´ve used their C+ in my 2018´s manual transmission and it has been great and smoothed out the gear engagement a bit.
Others?
Others?
I liked Red Line, I never had any complaints except the price. But I’m equally happy with Maxlife, maybe that’s just me.
Yep, I think I would be, too. I have a deal offered for Red Line through Amazon through my Credit Card, so I´d get 6 quarts for about $70. That ain´t a Max Life bargain, but not bad for a premium brand like that. That´s what made me consider it.
Max Life is $25 a gallon. That´s really a bargain.
While I don´t see added capacity being a risk, I also don´t see a huge advantage other than thermal and detergent capacity. These transmissions seem to do just fine with the standard capacity and even some that have been seen that were somehow shipped from the factory not completely filled. The transmission wouldn´t know the extra capacity was there. But that has zero to do with the purchase. It has everything to do with having a drain plug to make swapping the fluid much easier and maybe more frequent. I might do 30k or 40k instead of 60k drains/fills, depending on how much towing I do.
I understand. It’s your vehicle. When I think of risk I think of it in terms of the hoped for reward relative to the risk taken. With the 8hp, it’s a solid transmission with wide application and an excellent reputation for both drive quality and reliability, and no known deficiencies in terms of the service intervals being too long. One of the best transmissions in the world, fair to say. So other than people asking about saving a few bucks using an aftermarket fluid or filter/pan solution, I don’t see much upside reward here in terms of modifications and so my tolerance for taking on additional risk in that kind of situation is almost zero, if that makes sense. Take care have a good day.
