Just tired of shoveling any deep snow at my 49 years of age. Would like to get a quality/reliable snow blower to ease the pains. Have a 30 ft. driveway and the side walks to contend with.
Thanks, Dale
Thanks, Dale
Please link your 2 stage blowers in that range with electric start.For that budget my target would be dual stage, 24", major brand but non-luxury engine make like B&S, in one of several brands. You can generally find something like that for $700 or less on sale so I see no reason to get the Toro 721 single stage linked above for $750 when it's a much lighter duty unit, unless you can find one on sale for $450 or less. "Sometimes" Home Depot has new purchase returns (just used enough to not qualify as new) for cheap, would be another way to save some money.
Some features like electric start seem nice but my back's not bad enough to need it so becomes more hassle to hook the extension cord up than to just use the pull cord.
However, if this is something you never need to lift into the back of a pickup or SUV, a smaller single stage is going to get the weight down far closer to a manageable level, though anything self propelled (proper self propelled wheels not self propelled from the paddle hitting the ground to drag it forward) can be driven up ramps if they're grippy enough for the weather.
30ft long you say? how often do you get over 8" of snow.. you might want to get a toro 721E(208c motor)/821E(250cc motor) single stage they are good upto about a foot.. way easier to maneuver. Cleans down to pavement around 600-700 get the electric start if only for the first start of the season.
For 2 stage you need a bigger budget for a good one. the ariens compact 24 is usually around $999 at home depot.
Thats entry level for good 2 stage imo. I liked toro but it seems the recent models are not as good as 10+ years ago.
edit: your driveway is concrete or asphalt right?
$999 ariens.. which might be abit of a struggle to turn around for 30ft driveway
https://www.homedepot.com/p/Ariens-...ectric-Start-Gas-Snow-Blower-920027/301797901
Toro 721E
https://www.homedepot.com/p/Toro-Po...lectric-Start-Gas-Snow-Blower-38753/309982166 $679
They also have a commercial version without electric start for 649
https://www.homedepot.com/p/Toro-Po...elf-Propelled-Gas-Snow-Blower-38754/310206389
and 821 just has a bigger motor for $100 more probably not worth it.
and one with all the bells and whistles.. remote chute control etc for 749 721QZE
https://www.homedepot.com/p/Toro-Po...ow-Blower-with-Electric-Start-38756/310206476
It is not the thing for 2ft blizzards but 4-10" zip through and alot easier to move around and steer on a short driveway.
Maybe once a year big storm I go snowblow it in the middle of the storm if I think its going to be over 14" but its still 10x easier than shoveling.
God I wish I could get away with that…My North Carolina snow blower. Works pretty good with leaves too. Way less than $900.
If you don't mind doing some minor mechanical stuff, a good used one is fine. I got the $100 one and have had to split it to change the blower belt, reinforce the auger with some sheet metal, foam fill the tires to get rid of the tubes. A new cheap simple one should go for 20+ years with a small driveway to do.Get a used Ariens or Toro 2-stage in the 8hp/ 24inch wide size. Spend about $250. The new ones haven't really gotten better.
Look for bearings instead of bushings for the auger and wheel axles. Test how flimsy the controls are for the chute.
Engines are pretty robust, though Tecumseh are worse than the rest. But you can re-power cheaply.
I'm getting ready to get the Ego 2-stage this weekend.The Dark Horse option. There’s a cheaper version with smaller batteries too.
I’m getting the eGo 2-stage next time around.
https://www.acehardware.com/departm...Impact&utm_campaign=141568&utm_keyword=611504
Look at any brand when on sale? What do you mean by "steer"? You propel it in a straight line, then disengage the drive, and turn it. I've done that fine for years.Please link your 2 stage blowers in that range with electric start.
Yes they are real self propelled.. but how well does that steer when you have a 30ft driveway and its not one of the fancy power steering or wheels that unlock models.
I am currently using a toro ccr 2450 from 1992.. its dying .... from rust.
Friend has the 721 and its a total beast.
You can find off brand or troy bilt single stage for $550 with 208CC motor.
https://www.hartvillehardware.com/product/sku-703025/Single-Stage-Snowblowers
I like my toro so much the extra 100-200 for the premium brand is worth it over 20 years to me.
