Two days ago, I watched a yt video of how to install a very small circuit board in an under hood fuse box to trick it into charging at a little higher Voltsge so the Plates of an AGM battery will not sulfate up and significantly shorten battery life.
TF, you might want to look up the availability of that F150 AGM battery Voltage boost board, and the yt videos about installing it.
