Here's the Purolator P1 PL14612 oil filter off my '15 Yamaha FZ-07. I bought this bike this year, broke-in hard and this was the 4th OC. The OCI was ~1500 miles and the oil was Rotella TTT 15W-40.
Here are the previous filters cut open: http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3810967/Yamaha_vs._Fram_TG_vs._Bosch_v
Here's the P1:
Can someone decipher the date code on the filter: F09F08E3
Yeah, first thing I noticed… metal end cap with bypass came right off. No evidence of adhesive remaining on inside of end cap, just faint black stains. It just didn't bond to the metal (dirty, oily, whatever). Other end cap is secure.
Second, the spacing near the crimp is not great and the pleats on either side are noticeably creased in. Third, the yellow bits on the filter are just the paint from the can.
On the previous oil filter I cut open… I didn't really pay attention to pleat spacing, spacing at the crimp or signs of tearing. However they looked good overall. While the Bosch filter was similar in construction (I understand it should be), IIRC, the pleats around the crimp looked better and both metal end caps were secure.
*Disclaimer*
The method of opening the filters has been the same, punch a bunch of holes near the bottom seam with a flat-screwdriver and use tin-snips to cut open. On this particular filter, I dented the metal end-cap in a couple spots (can be seen in photo above, from punching with screwdriver)… it might be possible that I hit the pleats. However I kind of doubt it.
So lastly, a good look at the pleats near the crimp and I see what looks like signs of them starting to tear. Only on the lower end (opposite of bypass) and only the pleat of either side of the crimp (the ones that are creased in.
In the picture below you can see the lighter color "fuzzyness" near the adhesive. They're NOT torn thru, but definitely starting to.
Whether the "beginnings" of tearing are my fault or not… just based on the short OCI, pleat spacing near crimp, creased pleats near crimp and not adhered end-cap. I'm hesitant to try another, maybe. I replaced this with another Bosch because I get them at cost and from what I remember it looked good from my previous OCI.
Here's the P1:
*Disclaimer*
